04-14-2011, 09:13 PM | #1 |
can you lay frame with a 15 inch wide rim
I am building a 69 c10 full air ride with a step notched rear frame and i am away working at the moments and a friend found me a set of 20s the fronts at 20x8.5 with 4.5bs witch will work perfect but the rears at 20x15 with 6bs. if i was home i would go measure it myself but i am not can someone plz tell me if there is enough room between my box sides and frame rail to tuck a rim the large.
http://www.truckinweb.com/features/0...c10/index.html i found this truck so i am thinking it might work |
04-14-2011, 09:48 PM | #2 |
Re: can you lay frame with a 15 inch wide rim
Are you really wanting to run that wide of a wheel? If it's just cause it's a good deal somewhere, you might wanna rethink it a little. That's just a really wide wheel is all, going take some work getting that to fit right.
04-14-2011, 09:59 PM | #3 |
A 15" wide wheel will physically fit between the stock frame rail & fleet bedside (I've had 15x15's mounted in that space before) but not by much. You're definitely going to have to narrow the housing & build a different rear suspension w/that 6" back spacing though.
Laying frame though? That's going to be tough as the wheel/tire will have to be tucked in because there will be interference w/the bedside (alot of interference I'm guessing).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-14-2011 at 10:01 PM. |
04-15-2011, 05:48 PM | #4 |
It'd be alot cooler if you did
Anything is possible, it would look cool that's for sure. I wouldn't do it just for the look though, you better be running 10s If you've got tires that wide.
Posted via Mobile Device |
04-15-2011, 06:51 PM | #5 |
I remember back in the late 80's and early 90's seeing pro street '88-'90's Chevy trucks running the factory V6 motors that were nearly stock.
04-15-2011, 10:03 PM | #6 |
well just order my rims Bonspeed quasars 20x8.5 front with 4.5bs and 20x14 rears wiht 6bs and for tires some Toyo Proxes 4 245/40R20 and for the rear some Mickey Thompson Sportsman S/R Radials 31x16R20 i will post up some pics ones i get everything in place.
yes i know i custom rear end is in order thats the next thing on the list ones my rims and tires show up. I dont think my truck will do 10s but it wont be a slug either it will be getting an ls 376 with 515hp and a T56 6 speed it should beat those 80 v6 chevy trucks to the end of the track by a foot or two. |
04-15-2011, 06:40 PM | #7 |
Quick (example) pics from his link above...
04-15-2011, 10:47 PM | #8 |
My buddy Roger @ RPL Customs ordered/installed the wheels for this truck. He was the shop manager @ Stoked Out Specialties where the interior, underhood detail stuff, & tweaks to the suspension were completed.
04-16-2011, 12:10 AM | #9 |
really just interested could you ask him if the rear frame was narrowed to fit those tires or did they actually fit between the stock width frame and box sides ?
04-16-2011, 12:37 AM | #10 | |
Also.... that truck isn't really that low. That's where/when you'll really start noticing issues w/fitting all that rubber. It had standard c-notches installed into the frame & the rear housing wasn't riding inside the notched area. Both of my previous daily drivers w/c-notches had the rear housing tubes up into the notched area about 1" which would be the equivalent of about 8" rear drop.
04-16-2011, 12:53 AM | #11 |
awesome thanks for the info i guess i will find out in 5 weeks when my rims and tires arrive what clearance issues i will have if any. My frame has been step notched 6 inches behind the cab with the box floor raised up and a weld in notch in the frame. I plan on tubing the rear a raising my tubs level to the box sides should give me plenty of room.
07-29-2012, 04:50 PM | #12 | |
