Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-17-2013, 01:44 AM   #1
ol'blazer
ol'blazer's Avatar
Mono block amp with two 10" subs?
Right now I'm running two mtx subs off a 300w phenox gold amp... I want a little more out of them.. Do I have to run a 2 channel or can I run a mono block?
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 05-17-2013, 04:52 PM   #2
jimmydean
jimmydean's Avatar
Re: Mono block amp with two 10" subs?
You can run a mono block as long as the load of the 2 subs isn't less than the minimal impedance of the mono amp.
2 subs @ 4ohm each run in parallel = 2ohm load at the amp for 1 channel. If the amp is 2 ohm stable, you are good to go.
So depending on what subs, what amp, and how you wire them together, you can certainly do it.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-17-2013, 10:06 PM   #3
ol'blazer
ol'blazer's Avatar
How would I go about wiring a mono block into to subs?. Do I run from the amp to one sub then from that sub to the second one?
Tyler
1980 2wd blazer
Old 05-20-2013, 03:02 PM   #4
jimmydean
jimmydean's Avatar
Single or dual voice coil?
If single voice coil (assumed in the first response I gave)
Run + of the amp to the + of each sub, - of the amp to the - of each sub.
Wired this way, two 4ohm subs will be a 2ohm load on the amp. If the amp can handle a 2ohm load.
But since I have no idea what amp or subs you have, I am making a guess that the mono amp can do 2ohms and that your subs are single voice coil 4ohm subs.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-20-2013, 01:56 AM   #5
king-918
king-918's Avatar
what model subs you have
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-20-2013, 11:21 PM   #6
ol'blazer
ol'blazer's Avatar
i have two 10" mtx thunder 6000 subs.. im not sure what amp im getting yet
Tyler
1980 2wd blazer
Old 06-17-2013, 09:00 PM   #7
76stepsidechevy
How is your amp wired now ? you might get some more juice out of your amp by bridging it to mono and wiring the two subs in paralell provided the amp can handle the lower resistance.
76stepsidechevy is offline   Reply With Quote
Old 06-19-2013, 01:34 AM   #8
ol'blazer
ol'blazer's Avatar
i switched my setup to a 1000w monoblock with two 12" dual voic coil subs wired in parallel
Tyler
1980 2wd blazer
Old 06-26-2013, 11:54 AM   #9
tubbedII
needs more $$$
tubbedII's Avatar
It's been about a week now, have you ran this set up? I only ask because this wiring puts the load at 1 ohm (given you have 4 ohm 12's) and you have to have a pretty decent amp in order for it to handle this. If it's not 1 ohm stable it will constantly turn off or worse, burn out.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
