Old 05-19-2009, 10:11 PM   #1
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
my truck build!!
Alright I thought I might as well start a build thread since I might actually start doing some work again. Quick history on my truck 1969 fleetside longbed custom/10. Basic 350/th400 combo with a open 3.08 in the rear. found my beat up green truck in stonyford california. Was my aunt's truck for a long time and was also my great uncles till he passed away. He was pretty mechanically skilled but he did some weired stuff. Reinforcing things with chicken wire that didn't need it. funky wiring and an A/C power socket that gives off unregulated DC from the alternator at a flick of a switch . Anyways probably should add some pictures.Brought home my truck about a year and a couple months ago so this is just like a quick montage of what ive done and where i am now.
some pictures when i first found it
mikajo39 is offline   Reply With Quote
Old 05-19-2009, 10:17 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Re: my truck build!!
made sure and keep the registration up to date or put a non op on it so you can keep the old blk and yellow plates. Other wise the DMV might take them from you when you re-register it.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 05-19-2009, 10:19 PM   #3
mikajo39
mikajo39's Avatar
Don't worry we took care of the regestraion and all that at least a month before we took it home haha my dad is always on the ball with that stuff
Old 05-19-2009, 10:24 PM   #4
mikajo39
mikajo39's Avatar
So the engine comparment got cleaned next
then a few days later the fuel pump crapped out fun..
Then the truck was enjoyed for a good 6-8month period while it got a true dual exhaust and other various things like a stereo higher output alternator, voltage regulator, new carb, ignition upgrade, new plug wires, spark plugs, and a really thorough cleaning
Old 05-19-2009, 10:27 PM   #5
mikajo39
mikajo39's Avatar
Then me and my bud got bored and said he said "hey maybe we should paint your bed it looks bad..." I agreed.
and then after sanding and rust killing in the cheap spray paint primer stage
then all done
Then I got bored again and said hey dad lets fix the a/c since it still had a full charge of R12 and the clutch was just burned out on the compressor easy right? well it took about 6 straight hours but i got it! then the engine ate dirt
Old 05-19-2009, 10:34 PM   #6
mikajo39
mikajo39's Avatar
So i finally got outside today to take some pictures of the truck as it sits now waiting for its new engine. and as i tear down the engine piece by piece in the little spare time i actually have.
The timing chain sprocket pretty much ended up shearing itself on about half its circumfrence which was pretty bad
The timing chain was super slack and chewed up the timing cover on the way out as well
its organized chaos at the moment under my hood
she also stopped running at 91280 miles exactly
Old 05-19-2009, 10:18 PM   #7
mikajo39
mikajo39's Avatar
So I found it Popped in a new battery then got it ready to go but then we realized we had a starter that was totally burned up. So we had to drive home which was 5 hours away and come back next weekend with a new starter that didn't fit. So me and my dad pulled the guts out of the new one and put it in the old one and off we went! It was a slow 50mph drive home I was surprised it got us home It had a water leak (freeze plug) and later we found out the U-joint were practically turned into dust. anyways we got it home and started to figure what needed to be done. we changed the U-joint first
Then i went to the back with my trusty hat and soldering iron to fix some really bad connections
Then I proceeded to clean the interior and freshen up the engine compartment sadly I could'nt find a picture of my interior after i cleaned it up so heres my current dirty interior
And my option list
Old 05-19-2009, 10:43 PM   #8
allen123
It'll buff out
allen123's Avatar
Nice build!
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 05-19-2009, 11:03 PM   #9
mikajo39
mikajo39's Avatar
thanks I do what I can to it during the school year and then splurge over the summer ,find more problems fix. rinse wash repeat type of thing. I need to find a job but right now its almost impossible too
Old 05-19-2009, 11:27 PM   #10
sleepertruck72
sleepertruck72's Avatar
mikajo
Thats a nice looking truck to start with ! Good luck with it
Thanks for all the pics
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 05-19-2009, 11:36 PM   #11
mikajo39
mikajo39's Avatar
Originally Posted by sleepertruck72 View Post
mikajo
thanks! A thread isn't very good without pictures so I posted some. I've got tons my dad is the type who likes lots of pictures to document whats going on . Shes a pretty solid truck tad bit of rust in the driver side floor bout as big as a 50 cent piece and some rust in the rocker but otherwise shes clean which makes me happy. noticed your in turlock pretty close by! anyways should have some new posts soon so come check it out when i get more stuff up
Old 05-20-2009, 08:08 AM   #12
big_al_71
big_al_71's Avatar
/Good Job!!!
Thanks for sharing the picts..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 05-20-2009, 08:55 AM   #13
my67chevytruck
Under Construction
my67chevytruck's Avatar
keep at it....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-19-2009, 12:37 PM   #14
mikajo39
mikajo39's Avatar
Done a lot of work so far. Got my truck towed over to my uncle's so I could work on it, thanks to AAA. Soon as the truck got there we broke out the cherry picker disconected everything and pulled then engine. We got it on the stand and I began the teardown as my dad an uncle removed the transmission. I found some pretty bad looking bearings and a strange choclate milkshake looking mixture in some bolt holes which I think is water in the oil? Cylinder walls looked pretty good ridge at the top wasn't bad either. Cam had some flat lobes, and there was a lot of stuff in the pick up and the bottom of the pan. Picture TIME!
Old 06-19-2009, 12:43 PM   #15
mikajo39
mikajo39's Avatar
I had my transmission inspected and it was thrased( according to aamco) and they wanted to rebuild it for 2100 dollars NO WAY! SO we bought a new Tci streetfighter for half of that It just showed up yesterday so I don't have pictures yet but will soon. My new engine also showed up My powercrate 350 from yearone it made 403.6 hp at 5700 rpm and 414ftlbs at 3300 rpm. Pretty good for 2900 dollars, Everything is super clean and solid as well so I'm happy. While waiting for that to show up I did some cleaning primered my hood and other little things. The beer is my dad's Im a coke guy
The battery tray is thrashed and i don't want to buy a new one so I just cleaned it up
and the hood
found some rust in the rad support.. Blech!
and then here is me caught off guard
Old 06-19-2009, 03:47 PM   #16
mikajo39
mikajo39's Avatar
And the new engine! I forgot to post a picture I'm getting bad in my old age of 16
Yearone did a heck of a job crating this thing totally impressed!
Old 06-25-2009, 01:02 AM   #17
MisterE72
Keep Your Nose Clean
Nice looking motor. I wish I had one of those when I was 16.
MisterE72 is offline   Reply With Quote
Old 09-22-2009, 01:42 AM   #18
chevybuldr
chevybuldr's Avatar
So I hope you saved that original motor. 4 bolt block with a steel crank. Looks all original also. Cant beat that.
chevybuldr is offline   Reply With Quote
Old 09-22-2009, 02:48 AM   #19
vegaschevy
Great build so far
vegaschevy is offline   Reply With Quote
Old 09-22-2009, 10:02 AM   #20
mikajo39
mikajo39's Avatar
Originally Posted by vegaschevy View Post
Great build so far
Thanks, I got a lot done and now I'm just enjoying it for the time being, now it needs body work and paint.
Old 09-22-2009, 10:03 AM   #21
mikajo39
mikajo39's Avatar
So, this Is a really old video before I had all the bugs straightened out, But it'll suffice till I get some time to take it to the back roads and burn off that right rear tire!
Old 09-22-2009, 10:01 AM   #22
mikajo39
mikajo39's Avatar
Yeah it's all my uncle's garage kept the crank, block and the heads, pistons and rods are sitting somewhere in there too.I don't know if the pistons and rods hold much value though
Old 09-22-2009, 11:56 AM   #23
my67chevytruck
Under Construction
great work!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-22-2009, 11:33 PM   #24
mikajo39
mikajo39's Avatar
Originally Posted by my67chevytruck View Post
great work!
Thanks! I had such an idiot moment last friday, I was checking fluids and stuff in my garage before a friday cruise downtown, and I was sick and not feeling so hot and probably not so coherent. But I went to back it out and I usually just hop in and leave the door part open and hold onto it. Well in my sick stupor I left it to far open and hit the garage pillar! AGH! The door was fine but I bent my door hinge and had to readjust to compensate for the damage. It closes now but its not easy to close anymore. Anybody have any ideas on what I need to replace? door? or just the hinge assembly.
Old 01-09-2010, 11:52 PM   #25
Average Joe
Average Joe's Avatar
Cool project. Diggin' the powerplant. Any updates?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
