07-12-2021, 01:47 AM | #1 |
Is swap donor ac
I know it’s been covered but I can’t seem to find the info.
1971 c10 running a 2002 5.3 and 4l60e. Tbss manifolds What you using for motor mounts to get the donor compressor to work. I’d prefer not to cut the frame. Posted via Mobile Device |
07-12-2021, 07:09 AM | #2 |
Re: Is swap donor ac
I used Hooker Blackheart engine stands with F body mounts. Also used the Blackheart cross member to ensure driveline angles. With this setup, the mechanical fan positions perfectly in fan shroud. Engine sits low and donor truck 5.3 accessories all fit. A bit of frame clearance for PS was necessary in my build.
07-12-2021, 11:16 AM | #3 |
I cut the 1st hole off adapter plate, motor is in rear position. Stock compressor, will need the Cold Hose adapters. Mine 71....2001 5.3
