11-05-2020, 02:49 PM | #1 |
Clutch linkage for the 4-speed trans
Anyone running the standard linkage? I have a 63 C20, 292, 4-speed. The clutch fork has two positions for the rod coming from the pedal, and it looks like it could fall out of place.
I was thinking of using some safety wire to make sure I don't lose any parts. Anyone else done this?
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 11-05-2020 at 03:10 PM. |
11-05-2020, 03:37 PM | #2 |
Re: Clutch linkage for the 4-speed trans
you need a clutch fork return spring that goes from the tip to the frame.
1961 chevy K10 my build is------------61K10 build |
11-05-2020, 03:42 PM | #3 |
Pics?
1963 C20, small window, long bed 292, 4-speed |
11-05-2020, 03:57 PM | #4 |
MusicMan70 1961 GMC Suburban Last edited by MusicMan70; 11-05-2020 at 04:07 PM. |
11-05-2020, 04:32 PM | #5 |
11-05-2020, 04:54 PM | #6 |
I’m wondering how long that return spring is.
11-05-2020, 05:14 PM | #7 |
Likely about a foot long.
11-05-2020, 05:31 PM | #8 |
🤔 Really, a foot long? That’s a long spring.
11-05-2020, 05:38 PM | #9 |
Look in post #4 in that link.
It’s not all coils. |
11-05-2020, 06:28 PM | #10 |
Yeah, see what you mean.
11-13-2021, 09:01 AM | #11 |
Hey guys, I’m going through the “where in the hell does the clutch return spring go” also. I don’t think Bubba had mine hooked up correctly. I have a larger diameter shorter in length spring and no other spring. When I purchased a new clutch return spring for a 1966 c10 I only saw the larger diameter shorter length spring. I guess I will install the spring that I bought between the clutch fork arm and the linkage plate that holds the other end of the clutch adjustment rod.
peace Bud 1966 C10 4X4 1962 Impala Sport Coupe 1974 Corvette Coupe 1987 Suburban |
11-13-2021, 12:09 PM | #12 | |
Moderator
11-14-2021, 08:47 AM | #13 |
Thanks. Ordered one. Is the one of which I’m referring to for the clutch pedal itself?
11-15-2021, 11:20 PM | #14 | |
But Found Her 25yrs Later!
11-14-2021, 12:57 AM | #15 |
My clutch is set up with the push rod on the outboard hole. I figured it would give me more leverage that way for my leg. Did 6 cylinders use the inboard hole and wouldn't that decrease leverage at the pedal?
11-15-2021, 04:09 PM | #16 |
there is a notch or hole forward on the frame where the spring hooks into.
anybody know why there is two notches on the throw-out bearing fork?
11-15-2021, 11:53 PM | #17 |
I had half of that same spring above left hanging on the frame of my 63 when I got it. Of course, I took it off 6 years ago and don't remember where it was hooked into
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
