Old 10-07-2019, 10:07 AM   #1
Lakeside65
Lakeside65's Avatar
New to me 66 C10
Hey guys. It’s been about a year since I was last on here. I had a build thread going for my 65 but stopped posting whenever I decided to part the truck out. 6 months went buy after parting out and I found a running and driving 66 in Bixby, OK. Drove out on a Wednesday and cruised it home to Missouri that night. Here are some pictures of her over the last few months I have owned her. I am working the bugs out right now. Planning to pull in the shop soon and paint the cab and front clip to match the patina blue, and I will pull all of the trim off, order new clips and try to straighten the trim out as much as possible. I have new springs, shocks and shock relocators for the rear that will be dropped 1” more. I’m also planning on a blazer tank swap between the rear rails and doing a bolt in notch.
2013 Crew Cab 6.2 - 66 C10 Long Bed on Bags
66 C10 Build Thread
Lakeside65 is offline   Reply With Quote
Old 10-09-2019, 09:40 AM   #2
88Stanger
88Stanger's Avatar
Re: New to me 66 C10
Well, welcome back. Nice start on the new ride!
88Stanger is offline   Reply With Quote
Old 08-18-2021, 03:25 PM   #3
Lakeside65
Lakeside65's Avatar
Well, here we are almost 2 years later and I'm back with another update on my first build. Life became a priority as we just had our first baby 5 months ago and that put a hold on the truck for awhile. I ended up tearing everything down, doing some fab work on the rear of the truck, bagging all four corners and completely rebuilding/replacing just about every suspension part, new wheels and tires, boyd's fuel cell etc etc. Anyway's, all that is left to finish is wiring, and install the new carpet and reupholstered seat. I am so anxious to see how it runs and drives with the Holley Sniper and all of the new suspension. I will get some photos uploaded soon.
Old 08-24-2021, 09:40 AM   #4
Lakeside65
Lakeside65's Avatar
Hello Everybody,
As promised, here are some progress pics through the fab process. I originally cut out all of the cross members thinking I was going to do a real step notch but later decided that I didn't want to loose all my bed space. I had to notch one crossmember to clear the rear end. I also included photos of my seat, old and new done by Lambs Auto Upholstery in Springfield MO. One of my favorite parts so far is cleaning up the radio hole where the previous owner took a pair of tin snips to clear out room for a late model radio. I bought a manual valve bracket from ThorBros and had my dad 3D print a bezel to cover the old hole. I am super happy with how it turned out.
I went ahead with the Boyd's fuel cell and in tank pump with plans on going LS in the future. I also welded in a filler neck to the inside of a jerry can that will mount in the bed of the truck and will fill the tank under the bed.
The truck is currently getting the wiring finished up by Rust2Rodz here in Marshfield MO as well as getting a Holley Sniper installed. I really wanted to do this on my own but we just had our first baby girl and that has taken priority over the truck. That should be done soon and I will make sure to grab some photos of everything once I get the truck back. Stay tuned, hopefully I am back on the road this year after about 14 months.
Old 08-24-2021, 09:40 AM   #5
Lakeside65
Lakeside65's Avatar
More Photos...
Old 08-24-2021, 09:42 AM   #6
Lakeside65
Lakeside65's Avatar
One More for now
Old 09-02-2021, 06:09 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice work, thanks for the updates.
Old 10-07-2021, 12:57 PM   #8
88Stanger
88Stanger's Avatar
awesome!! I am excited to see your progress. I have bagged all 4 four also, going to with similar EFI (MSD's version - still built by Holley, matches my Dist. box, wires and so on)
John 3:16 - Saved me... God Bless
Old 10-18-2021, 12:29 PM   #9
Lakeside65
Lakeside65's Avatar
Made some good progress over the weekend, got the bed on and bolted down and finished up the fuel filler jerry can.
I attempted my first drive to o'reillys (about 5 miles from the house) and I got about a mile up the road before the truck started stumbling and running like crap. I knew these snipers could be kind of weird so I made my way back home to try and figure it out. I had to drive by the city golf course on the way, and at this point the truck would not go over 10 mph and was popping and backfiring like a gunfight, I'm sure everyone watching was real impressed. Anyways, I limped it back to the driveway and knew I needed to check the timing so I hooked up the light and set static timing to 15 degrees in the ECU and hit the key, and it backfired like a 9mm going off. Scared the crap out of me, my wife and my baby sitting there watching. Long story short, I found the distributor hold down bolt had loosened and the distributor had spun enough that when I set static timing and the ECU couldn't try to make up for how far off it was then it had to fire with an exhaust valve open. I'm not too knowledgeable compared to most, but that is the only thing that makes sense to me. Lesson learned the only way, the hard way. After I got timing set everything ran smooth as butter and I got the first 10 miles on her. Of course, I ran into more issues. The pinion seal is leaking which wasn't a big deal with the bed floor installed, but with the bed floor out that gear oil is slung EVERYWHERE and I can only assume the cars behind me might get a bit of it as well. Hopefully I can get that fixed this week. I am so close to being back on the road and it is an awesome feeling! Enjoy some photos of the truck and fuel filler attached.
66 C10 Build Thread
Old 10-18-2021, 01:56 PM   #10
The Rocknrod
Moderator
Cool, we all have to do some adjustments when we first start and drive em. That 5 Gallon Jerry can looks neat.
