Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 09-11-2011, 04:35 PM   #1
C/60 Trim Question
I spotted a single axle C/60 tractor today.The business is closed today and fenced,so I couldn't get a closer look to cure my curiousity. .What has me wondering is,did these trucks come with the same trim level options or just standard and custom like trucks prior to these? This truck,I believe is a '70 or newer because it has the raised pod roof panel. Could be a '69 if all the clearance lamp lenses were changed. It has the 67/68 type Custom door badges and fender side markers. I know even the bigger 67/68s didn't have these round clearance lamps. The truck is definitely an upgrade cab with stainless window trim and that's a I could see. I'm definitely going back. This place is near me,has a junk yard,sells a few vehicles used,and is primarily a towing business. I want to see what their plans are.
Old 09-11-2011, 08:01 PM   #2
Re: C/60 Trim Question
I know this is something most of you guys won't know. I hope someone who knows their GM trucks will see this.
Old 09-11-2011, 08:28 PM   #3
Livrat
Member #1049
Livrat's Avatar
From the dozen or so C40-60's I have parted out, the 67's had 3 tear drop bolt on cab light without the raised roof, 68 had 5 of the same, the 71-72's had the fireman hat lenses with the raised roof. I have seen one with factory AC and AM-FM
As far as I know they did come with the "custom appearance group" option.. which was bright grill work and stainless window moulding and chrome wing vents,
First picture is a 72 C60 I parted with the custom appearance group option, 366cu, tach/vac
Second is a 67 C50 350 cu,plain jane and third is a 68 C50, 366 cu, plain jane..
I think they could be ordered with many of the same options as the c10-30's an additionally could have air ride seats,
Another observation is in 71-72's with the 366 big block they had a fresh air vent on the drivers side of the hood and with the 427 big block had them on both sides with a "427" emblem.
Livrat is offline   Reply With Quote
Old 09-13-2011, 07:52 AM   #4
So,that first one with the Custom appearance option had the 67/68 style "Custom" door badge? This one is like that. It has the 69/70 style C/60 badge. I wonder if 71/72s had those badges or Custom/60,etc. I must not have been paying as much attention all these years as I thought I had. I'm just curious since 89/70s designate the Custom appearance with 67/68 badges,if 71/72 is non-typical,too. Where's Too Much Stuff?? Eric,I think you had mentioned you had CST/50 or 60s?? Or some other upgrade badges? It would seem a Custom would have a fender badge like that and doesn't. I'm taking pictures today.
Oh,and what do people do with the 366 cranks?
Old 09-13-2011, 10:04 AM   #5
Livrat
Member #1049
Livrat's Avatar
After a second look at my other pictures, Yes first pic is a 72 C60 and it has the 67-68 "custom" door badges. Took a look thorugh a few more pictures I have and here is a C40 (not sure on the year) that looks to have the appearance group but no door badges. all the fender emblems I have ever seen are just the different years of C40, C50, C60, never a "Custom/60" etc.
I have also noticed there are different hood bowties some are flat and some are raised at the top.. (havent figured out if its a year thing or model difference)
The 366 cranks are steel and the same as a 396 and 427 car cranks
Old 09-13-2011, 07:04 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
Tim, the only oddball big truck emblem i have is a C/50- 8-366.
Otherwise they have all been bowtie over 40,50,60 (like the 67-68) or C-40, C-50, or C-60. I have noticed the 67-68 custom upper door emblem on bigger trucks, but didn't pay attention to what years they were on. I know those emblems came in black or chrome if that means anything...
Even on my GMC emblems, after 3500 series they are just V-six, V-eight, or diesel.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-11-2011, 09:57 PM   #7
Good info. I could see the driver side and it had the chrome vent w/o the 427 emblem. It has Gasoline labeled at the filler and I wondered if it might have the 366. This place is closed n Mondays. I can't wait till Tuesday to check this out.
Old 09-11-2011, 10:11 PM   #8
Livrat
Member #1049
Livrat's Avatar
One thing to keep in mind if you end up purchasing, the 366's have no resale value,(at least out here) I tried to sell the rebuilt 366 out of my 72 for months, ended up robbing it of the steel crank shaft and scrapped the rest.. 427's on the other hand are desirable
Old 09-11-2011, 10:21 PM   #9
68panelman
68panelman's Avatar
From what i have seen, The local yard has a 69 c/50 with cab light pods. The lens are a round /flat top style. think the are original since they faded to all white. I beleive this type was for low clearance body styles like box/ car carrier.
68panelman is offline   Reply With Quote
Old 09-12-2011, 06:22 AM   #10
'69 was the first year for the all plastic round clearance lamps mounted on raised pods. The first lenses were the flat topped and they changed to the domed lens by the '70. My guess is the change was made to give the lights more visibility.
I wish this thing did have a 427. I'd rather it had a Detroit diesel. If I bought it I would restore it for old truck shows. I'd get a fifth wheel camper and low-boy to put it to work.
Old 09-14-2011, 07:35 AM   #11
I'd just like to go over this truck,paint it up,and put the fancy pickup interior in it to have something to bobtail into antique truck shows with. I have friends with old big trucks and they've been bugging me for years to get one. It just seems fitting to get one like this. A lowboy would be nice. Or,better yet,a Landoll tilt bed would be awesome. Maybe find a steal on a 5th wheel travel trailer. Yeah,I know, I'm just dreamin'. That's what gets me by sometimes. Here's a few other shots:
Old 09-14-2011, 06:08 PM   #12
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
stupid question, will these cabs fit our trucks?
John
1999 Toyota Tacoma 4x4
Old 09-14-2011, 07:52 PM   #13
No. Although they share many body panels,they use a different floor (due to different frames) and different cowl (due to the different front clip). The fenders bolt up different. The front clip is shorter so the engine sits back into the cowl deeper.
Old 09-14-2011, 10:42 PM   #14
oldblue1968chevy
darn lol
John
Old 09-15-2011, 06:39 AM   #15
Yeah...oh well
I sure would like to drive this stout little thing around. That big block sounded tight! Just imaging 9 shifts leaving the cruise-in.
Old 09-15-2011, 02:13 PM   #16
va72longhorn
va72longhorn's Avatar
What kind of price tag do (or did) they have that, special k?
va72longhorn is offline   Reply With Quote
Old 09-15-2011, 09:44 PM   #17
$1,500 OBO. It's driving me nuts. If you are interested I can go and buy it with you as mine because they know me. I'm thinking $1,000,maybe as much as $1,200. They just got it in and I think a quick sale would be motivating to them.
Old 09-15-2011, 10:37 PM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My book said that Custom Appearance (Z61) and Custom Comfort (Z62) were available. With Z62, a cloth seat was standard, unless it had a 10-speed.
I'd love to have a pair of those hood vents.
Aren't those 427's, a tall-block engine, though?
Member Nr. 2770
Old 09-16-2011, 07:24 AM   #19
The 366 is a tall deck truck motor,too. The 427s had the vent in both sides and a 427 badge added. This one has those Custom packages. The front trim is bright work under the white paint. Apparently the door panels still came in metal with the upgrade and the horn button wasn't chrome. It does have the fancy dash knobs. The Custom badge on the glovebox door is removed on this one.
I always wanted to get one of these and put ln a fancy pickup interior. I have olive door panels,seat belts,and visors. The rest is available. I have a friend who has a N.O.S. olive steering wheel. That thing baffled us because it was obviously N.O.S.,67/68 style,and olive wasn't an interior color in those years. I guessed that maybe it was a medium duty wheel from 69-72,since the wheels are the same style. My hunch was confirmed when we held a 67/68 pickup wheel to it and it fit just inside his. These trucks have an identical wheel but just a tad bigger.
Old 09-17-2011, 12:44 AM   #20
va72longhorn
Havent been on for a couple days, sorry for the delay, Special K. Yeah, if youve heard it run and its drivable, Im interested. I have two forty foot storage trailers that need to be moved in the near future plus Ive always wanted one of these to pair with my 20 ton gooseneck. The body doesnt look like it has alot of rust in the pics. Do they have it on the road currently?
Old 09-18-2011, 09:59 AM   #21
They just got it in. They won't be tagging it. It does have rust,but nothing to scare me off. I can get better pictures and get more info for you. Send me a PM and we can swap phone numbers. I can't buy it and would like to at least see someone else get it that would appreciate it like I would.
Old 09-22-2011, 08:31 AM   #22
va72longhorn
Did you get my Pm the other day?
