biulding a 1/4 mile 7 second truck
I saw a 72 in hot rod (i think) about 10 yaers ago. it was a lwb , it wasnt choped ,just tubbed and had a big block. he was running the 1/4 mile in the 7s. it was awsome!!!!! my next progect is to biuld a truck like that. I would like to know what i should use for rear suspention, ( 4 link or ladder bar).I am going to start out with a sb till I can aford the big hp bb. any more info on a drag truck would be cool.
maybe the guy with the 7 second truck is on the board some where? |
check dragtruk.com
there are a couple of trucks running those times. I believe they are on the stock rear suspension.
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
So Many Ideas, So Little Money
I'd say 4 link, much mroe adjustability. just a thoughtfor down the road too, if you wanna hook up you need te chassis to have a good rake, not te body, the chassis, yu look at prostock, it looks all low, but thats jst body, the frame isat a goodrake, you need that or you'll smoke em orever, jsut a lil. teahin lesson early on.
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
Hi Crew 70. Check out dragtruk.com. Most of the 67-72s are running bb and have stock but topped trailling arms with coil over shocks. I have a 2 bolt 454 done for $400 can make 700hp with 2 bolt. Let me know.
chevy2race what do you mean by rake and generaly how much 3 degrees ,5, 10 ??
awsome truck
try searching for "joe delahay" first truck to do 200 mph, its a wild looking Truck and hes from Canada to, awsome photos of one of his nitrous fries and when his truck doors blew off at 200 mph or sumthing, crazy!
7's will take at LEAST 1200 hp in a 3000# vehicle. Maybe more. My buddies 90 Camaro ran 8.67 @ 163. It dynoed 850 hp on the motor and had a 400 shot of nitrous, it wasn't quite sorted out before it was totaled, so it would have gone faster. It IS possible to get a truck to run that, but you need to get some solid advice from a professional chassis builder. Plan on spending around a minimum of $10,000 for a long block plus a large plate type nitrous system and another $10,000 for a back-halfed chassis with roll cage. Like everything else, add 50% for cost over-runs
awsome!!!!!!!!! drauling heavaly
crew it is decked line honed bored with toqure plates hope that helps Fl east coast
CCRider
WOW a Chevy truck running 7's with the stock rear suspension.
What size jet engine is mounted in the bed? ![]()
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
that dragtruk.com is cool there are some fast 67-72 trucks on there . 8-9 second trucks . one is for sale ? maybe I should save me some time and just by it? $27000.00 maybe not . although I wish I could.
