New 515 bbc
Just start up my 515 bbc would any one know what the timing should be at
The motor has 12to1 solid cam rec port dart cnc heads 1050 holley domanitor two stags of nos 250 on fist shot and 150 on sec shot for tranny its a th400 with a break 4500 stall rear end is dana 60 513 gears and 33x18.5 tires i hope this helps thanks |
Re: New 515 bbc
What fuel? 36-38 degrees would be a good starting point
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Re: New 515 bbc
i am runing vp 110
Re: New 515 bbc
don't spray it with 110. I would say a minimum of 114 on the spray.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: New 515 bbc
thanks what temp should it run at when i was breaking it in it was running 210. after it was broke in it was running 190 to 200 at a idle i have a 4 core rad and i think its 2500 cfm fan
Re: New 515 bbc
that doesn't sound bad. If you want to lose some weight on the nose I can recommend and awesome custom aluminum radiator company!
Re: New 515 bbc
sure i would like to put a aluminum rad
Re: New 515 bbc
Doug Herbert just sent me a flyer...they are selling Griffin Radiators for 159.95 your choice of size
Re: New 515 bbc
http://www.fsrproducts.com/
These guys are the bomb! they built me a custom two pass radiator shipped to my door for 278.00!
![]() Join Date: Jul 2007
Re: New 515 bbc
"its 2500 cfm fan"
Personally I prefer a fan (or fans) with 4000 + cfm with shroud. But since this is a race only deal... |
Re: New 515 bbc
any pics?
