05-06-2002, 02:41 PM | #1 |
aluminum radiator woes
I bought a new aluminum radiator that is application specific. Problem is the shop sent me one for an automatic. I have a standard tranny. Should I send it back or just plug the holes?
thanks, James
--------- 72 SWB K10 San Diego CA |
05-06-2002, 02:57 PM | #2 |
If it's a driver just plug the holes because it won't effect the perf. of the radiator.
05-06-2002, 03:03 PM | #3 |
Collector of rusty Items
Hmm..
I didn't know you could get one without the oil cooler. Mine all have the holes pluged. ------------------ Scrub 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
05-07-2002, 10:11 AM | #4 |
Registered truck nut
I wonder if you could use it to cool your engine oil. Maybe put in a remote filter at the same time. That would really help quench engine heat
------------------ MOUNT VERNON, WASH. STATE GOT MY BASES COVERED -Big and bad 70 CST Blazer -71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo, -Work in progress 72 SWB -72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd. -71, 3/4 ton, 402/400, Custom Camper -69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER" -69 Chev. short narrow 4x4 -69 Chev., lwb, utility trailer, 35" tires, Add or Delete Daily
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
