FOR SALE: Vortec Heads
Sorry this is the wrong board for this, but I have recieved some helpful tips on here so I wanted to give you guys first dibs.
I have a brand new, in the box fully assembled, set of Vortec heads for sale. I bought them for my new motor, but now I can't use them. My block had been decked before so, now my compression would be too high with the 64cc chambers for my blower. I would like to get my money out of them $500 or I would trade for a set of used aftermarket heads with larger chambers.I will take a decent offer, too.
69 Chevy ProStreet, Low and wild. 78 Corvette rturnpaugh@compcams.com |
woudl they fit the original block in my 69? it is decked .010 and is a 350 bored .030. thankss, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
These heads will bolt directly on your sbc. You would only have to buy the edelbrock intake for Vortec heads. Nothing else needed. Also, I actually flowed one on the flowbench and they flow what AFR says they do. 239cfm on the intake. You have to spend almost $1000 on a set of heads to get that. I am impressed by the Vortec heads.
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
You will also need center bolt rocker covers with the Vortec heads
Used to have a truck
You need different rockers and valve covers for the vortec heads in addition to the manifold. Also arent they 58 cc chambers instead of 64 cc? Even with flattops that would put your compression well over 10:1. Theyre good heads but the motor must be built for them.
I'd probably trade you for my 72cc chamber sportsman II's but I'd have to change pistons too and my ratating assy is all balanced and it would screw that up.
No truck :-( Last edited by mikep; 06-13-2002 at 09:50 PM. |
Psycho-billy Member
Vortecs are 64cc
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American ![]() |
They are definately 64cc. The fastburn aluminum vortecs are 58cc. If you run a flattop piston with a .039 head gasket and a standard deck height, you get about 9.3 to 9.5. Standard deck height is about .020". My problem is my deck is .003, I'm at about 10.25.
I could use a 72c head, that would put me in the low 9 range.
how about changing the pistons to the dished top for a lower ratio ?i know that could be a hassle if your block is already done. i hate to see you part with a *****en set of heads.
70 c10 stepside ,350v8, m-20 4 speed ![]() |
I didnt realize the iron heads were 64 cc. With my pistons It would put me at 11:1 which is too high for my blood. My next engine build will probably use vortecs though although I dont have any complaints about the sportsman II's .
No truck :-( |
You must be running a .100 dome piston. That would be tuff on gas unless you were at my altitude 6000ft. I run 11.5:1 in my corvette. I runs good on 91 octane here.
Yeah, I run .125" dome speed pro hypereutectics. It would put my compression a wee bit on the high side for 92 octane at sea level where I live.
No truck :-( |
From all of my research the last months the heads are definently 64 cc and a set of flattops with 4 brow reliefs will give you about maybe 9.4(9.6) : 1 compression and 2 brow reliefs should give a 10:1 compression.
jim pace parts have the conversion for 745 includes heads assembled and intake and gaskets evrything even the sparkplugs
67wyo chevy, I know you are trying to be helpful, but I think the proper board edict would be not to post comparable price options on someone elses "For Sale" post. Just a thought
Just sitting here contemplating contemplation. |
