Old 04-14-2002, 01:36 PM   #1
dion
72 Cheyenne
dion's Avatar
Post Still having problems with Oil Pressure
We took the new Pump off and it seemed fine, put a new spring in it and put it back on. It's better now but will still drop when I gun it, any ideas?
72 Cheyenne C20
Built 350/T350
AC/PS/PB/AT
Dana60 Leaf
Factory Saddle Tanks
San Diego, CA
Pics of My Truck
<A HREF="http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src=
ph&.last=1" TARGET=_blank>http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src=
ph&.last=1</A>
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 04-14-2002, 01:41 PM   #2
Desert Rat
Desert Rat's Avatar
Post
I hav BBC that drops to 5 at idle runs sweet,dont smoke,lotsa power.probably like my motor worn main bearings!
Desert Rat is offline   Reply With Quote
Old 04-14-2002, 02:57 PM   #3
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
Post
you have any baffling inside the oil Pan? sounds kinda like when you get on it, all the oil is shoved to one area and the pickup starts sucking air. Also check your drain back holes under the intake manifold. you can have alot of oil get stuck up in the valve covers and valley area when you get into higher RPMs. that's the reason I put a 7 quart oil pan on my engine. gotta keep it well supplied with oil when running 7000 RPMs and 420 horses.
Seth Petro
http://photos.yahoo.com/cowboy_55303
http://members.fortunecity.com/blackhawkdc/
1992 Chevrolet S10 4x4 "Lil' Blue"
1969 Chev C10 Stepside "Steppie"
Custom exhaust artist
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 04-14-2002, 03:04 PM   #4
racedvl
racedvl's Avatar
Post
I have oil pressure problems!!! The higher the rpm's the lower my pressure is. My temp fix to that is a quart of gear lube in the crank case. That's right, I have some 80w90 in my engine. Keeps my pressure up at all times. I pretty sure that the cause of my woes is a engine bearing somewhere out of spec. My fix will soon be a a diffrent engine. Try a quart of gear lube, see what it does. I have been running mine this way for over a year now. So don't be afaid.
http://hometown.aol.com/racedvl/racedvl69index.html
Woodstock,IL.northwest of Chicago
It's not what you buy, it's what you build!!
I did not climb to the top of the food chain, to become a vegetarian.
For some pics of my truck.
racedvl is offline   Reply With Quote
Old 04-14-2002, 03:10 PM   #5
dion
72 Cheyenne
dion's Avatar
Post
Maybe my mechanic put too heavy of an oil in, the rebuild has about 500 miles on it now, the oil has been changed twice. It's right at the line now, maybe I'll try putting another half quart? A bigger oil pan might work. It smoked a little today, is that normal?
72 Cheyenne C20
Built 350/T350
AC/PS/PB/AT
Dana60 Leaf
San Diego, CA
Pics of My Truck
ph&.last=1</A>
Burnout
Idle
1972Cheyenne
1966/67Stouts
