Old 09-27-2005, 01:58 PM   #1
Hoosier
Hoosier's Avatar
Z'ed Steering Question
I want to begin Z'ing my frame on my 66 C10. My question is what do you guys do for the steering on a Z'ed frame. Add a joint to the steering column shaft?
Shane
Hoosier is offline   Reply With Quote
Old 09-27-2005, 04:15 PM   #2
fastbagged68
fastbagged68's Avatar
Depends on how big your Z is. You will probably need 2 joints, maybe 3.
fastbagged68 is offline   Reply With Quote
Old 10-12-2005, 03:34 AM   #3
BK
BK Built
BK's Avatar
you can also notch your UCA... if you get a piece of 2"OD tubing, say .125 wall thickness, cut the notch out, take a short piece of the tubing, cut it in half, and weld it in, youve got a notched UCA and arent losing any strength. thats what i did with mine, and ive seen 1 or 2 other done that way. keep in mind i did have 1 u-joint and the very top of the steering shaft where it comes through the firewall and connects to the steering column because i was running a firebird tilt column and they come through the firewall at a different angle.
BK is offline   Reply With Quote
Old 10-12-2005, 09:29 PM   #4
AesC10s
Chevy truck addict
AesC10s's Avatar
What is the uca?
AesC10s is offline   Reply With Quote
Old 10-12-2005, 09:40 PM   #5
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Upper Control Arm
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 10-13-2005, 02:26 AM   #6
AesC10s
Chevy truck addict
AesC10s's Avatar
thank you camaro thunder for clearing that up for me. DCP could you post us a pic of what u did to your UCA Please.
Old 10-13-2005, 02:37 AM   #7
BK
BK Built
BK's Avatar
Im sorry but i cant post many pics these days. the only pics i have from the frame mods are limited, and i cant go out and get a pic for 3 reasons. 1 - no digital camera. 2 - i live 8 hrs from my panel. 3 - it got burnt to the ground... but ill get some more pics eventually, espeically when i get started on my other one here in a month or two
Old 10-13-2005, 04:27 AM   #8
camaro__thunder
I cant wait for that NEW panel, I wasnt really a fan until I saw yours.
My Project 69 SWB
Old 10-13-2005, 04:48 AM   #9
BK
BK Built
BK's Avatar
thanks man, ive got some sick new plans i drew up, ill see if i can get the full pics scanned, but there are some tricks im going to pull out no one has seen on this new one... you all will hopefully be a fan of the new one!!!
