03-08-2006, 10:32 PM | #1 |
Are you familiar with these tools??
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted airplane
part you were drying. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...." ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. PLIERS: Used to round off bolt heads. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle. TWEEZERS: A tool for removing wood splinters. PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog **** off your boot. E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway. TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say,the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at ERCO, and neatly rounds off their heads. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50¢ part. HOSE CUTTER: A tool used to cut hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
Melissa 84 GMC Suburban 4x4 |
03-08-2006, 10:52 PM | #2 | |
Re: Are you familiar with these tools??
03-08-2006, 11:57 PM | #3 |
Where's my beer?
I have a few of those tools!
Paul How do you make the invisible, visible?.........You take it away. |
03-09-2006, 07:20 AM | #4 |
Excelsior, You Fathead.
I have most of them. Thats funny.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
03-09-2006, 09:32 PM | #5 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-09-2006, 09:30 PM | #6 |
What about a wheel chock:
Used for keeping a vehicle from rolling the rest of the way off the jack. Or,drop-light: 1)Used to light an area up until you actually need it. 2)Used to shock the user when he grabs the metal in the dark. 3)Used to melt anything plastic within arm`s reach.
03-09-2006, 11:37 PM | #7 |
Active Member
You forgot the specialty drawer, all the tools that met the; grinder, chop saw, welder, very important one-use, one time, knuckle bustin, mayworks specials...
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
03-10-2006, 12:18 AM | #8 |
That was good, thanks!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-10-2006, 01:03 AM | #9 |
I have seen it before but still pretty funny!
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
