08-08-2006, 11:06 AM | #1 |
Non-a/c to a/c conversion?
What is all needed to do this? Is the firewall different?
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
08-08-2006, 12:35 PM | #2 |
TOTY 2006
Re: Non-a/c to a/c conversion?
Cut three vent holes in dash (some say replace dash, your choice)
Firewall is different (I cut out an a/c fire wall and welded it into mine) You need these from A/C truck: Grab inside fresh air vent with vacumn pod Grab flapper vent under cowl and plastic bushing/nut grab A/C control and mounting bracket from dash compressor and brackets A/C cone both inside cab and engine compartment including all vacumn lines, cables, and all needed firewall gromments. Grab battery tray as it has bolt hole for A/C line bracket. Grab A/C condensor in front of core support. You can grab A/C core support or just drill the holes in yours. BUT FIRST, TAKE LOTS OF PICTURES before you start taking A/C stuff off!!! I am sure I have missed some small stuff, but if you take your time removing the A/C, you will see what you need.... |
08-08-2006, 01:04 PM | #3 |
I need to buy the a/c stuff. I don't have a single piece. Is it worth cutting the dash if you can get and a/c dash for a reasonable price?
08-08-2006, 01:04 PM | #4 |
member #16
firewall Here are the side vent templates. I have full size templates I can mail if you decide to go that way.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 08-08-2006 at 01:08 PM. |
08-08-2006, 01:48 PM | #5 |
This is in the thread FAQ section - http://67-72chevytrucks.com/vboard/s...d.php?t=160597
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-08-2006, 02:01 PM | #6 |
I am thinking about getting an a/c dash for around $60. I like this way seeings how the dash is already out of my cab. I would be interested in the templates for the fire wall. Let me know what I need to get you for them.
08-08-2006, 03:16 PM | #7 |
http://vintageair.com/
47.......'60-'72 Chevrolet / GMC Trucks Sure Fit Systems I've seen these in person and they are amazing and for what you get, surprisingly affordable. |
08-08-2006, 04:38 PM | #8 |
WTB this ad
Vintage Air looks factory on the interior if you use the original outer vents(which I chose not to).
It's also a clean install under the hood. Not to mention it comes with EVERYTHING but the pulleys and a belt. They have great tech support and a warranty. Most importantly it keeps you chillin! |
08-08-2006, 04:38 PM | #9 |
member #16
Sorry I wasnt very clear. All I have are the dash templates.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-08-2006, 04:52 PM | #10 |
see ten,
You're truck is very nice. Very clean. I love the interior. That is what is most lacking on mine. Did you get the truck in this condition or have to do a lot of stuff to it? |
08-08-2006, 05:34 PM | #11 |
The LuvShack Garage
IMHO, Vintage is the only way to go, unless your into the OE look
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-08-2006, 05:52 PM | #12 |
Is there something wrong with their site, I can't access any of the pages besides home.
08-08-2006, 07:50 PM | #13 |
I FOUND THE PERFECT AC CAB A COUPLE OF MONTHS AGO AND I HAVE STARTED GETTING IT READY FOR SMOOTHING OUT THE FIREWALL. tHE DASH IS UNCUT AND IT IS ALMOST IN PERFECT CONDITION. nO RUST ANYWHERE BUT IN TWO SMALL PLACES IN THE FLOOR. EVEN THE KICK PANELS ARE PERFECT. BUT AFTER LOOKING AT THIS POST I GOT A LITTLE WORRIED. I DON'T KNOW IF I SHOULD SMOOTH OUT THE FIREWALL NOW BECAUSE I WANTED TO PUT IN THE VINTAGE AIR SYSTEM. IT LOOKS LIKE YOU HAVE SOMETHNG BOLTED TO YOUR FIREWALL WITH THE SYSTEM. SHOULD I NOT SMOOTH IT OUT OR WOULD IT HURT.. dOES THE SYSTEM USE THE EXISTING HOLES?
08-08-2006, 10:10 PM | #14 | |
WTB this ad
08-08-2006, 11:03 PM | #15 | |
08-08-2006, 08:18 PM | #16 |
why couldnt someone add a a/c cooler inside the heater box . wouldnt it be easer to do some fibergass work to the box . electric switch in glove box for compressor clutch ( off / on ) ? just wondering
08-08-2006, 11:19 PM | #17 |
If you want to use the factory a/c controls, then you need to use the sure-fit system for our trucks. With that system, you don't want to shave your firewall completely because the hard lines coming off of the evaporator stick through the firewall just a bit.
If you're not concerned with using the factory controls, then you should use one of their Gen IIunits which is electically controled instead of the cables. With that system you can shave your firewall, but will have to have a bulkhead somewhere to get the lines into the engine compartment.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
08-10-2006, 09:23 PM | #18 |
I got that picture off of Vintage air's website, they sell them.
