Old 10-17-2008, 02:28 PM   #1
fun in dirt
fun in dirt's Avatar
Weatherstipping for leaky top
It's getting cooler & close putting the hard top back on for the winter. Last time it was on, I remember a major leak at the front corner and top of the door (vent window area). I don't expect it to be totally leak free, but this is a river flowing in. Think I may be missing some weatherstriping or something. Also the door glass doesn't fit very snug against the top either.
So I was sondering if y'all had some pics of your tops in that area?
Is there supposed to be something on the door itself too? All my weatherstipping is only on the top.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-17-2008, 03:51 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Weatherstipping for leaky top
Your body mounts are probably shot. It's causing the body to sag in the middle making the top not align properly.
The only thing other than the seals is the drip rail deflector.
On the door, you should have the door caps above the vent window.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-17-2008, 04:01 PM   #3
Bentblazer
Bentblazer's Avatar
Hey Bouncy when I bought my Blazer all seals and deflectors were missing. If I understand correctly the top pic mounts to the hardtop and bottom mounts to door at wing window top?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 10-17-2008, 04:16 PM   #4
bouncytruck
SKINNY TIRES RULE!
Yes, the top one, the deflectors, mount between the hardtop and the windshield frame.
The door caps mount on the very top of the wing window on the door. Those do not get removed when you pull the top off.
bouncytruck 1972 K5
Old 10-17-2008, 04:19 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Them things have gotten pricey too
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-17-2008, 10:14 PM   #6
bouncytruck
SKINNY TIRES RULE!
What hasn't?
bouncytruck 1972 K5
Old 10-18-2008, 10:03 AM   #7
fun in dirt
The body mounts are good, but I don't have either of the two pics you are showing. It looks like my doors are cut up truck doors. They don't even have the screw holes where the door caps would mount.
Anybody got a pic of the drip rail deflector on a truck. Not sure I really understand where/how that goes?
Thanks for the help!
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 10-18-2008, 10:26 AM   #8
bouncytruck
SKINNY TIRES RULE!
My hard top isn't on the truck, so I don't have any pics, but it goes on the underside of the door glass frame to the underside of the windshield frame. They have about a 45 degree bend in them so the wide part can mount to the hardtop and the narrow part mounts to the windshield frame. Look and see if you have two holes in each spot, which is where it screws in.
Also, find yourself a tube of RTV or weatherstrip adhesive. Put a few spots on the bottom of the header seal just before you put the top on the windshield frame. Sometimes, driving around the block with the top loosely bolted can help settle it in place a bit more.
For the gaps around the doors, are they at the top rear corner of the door? If so, I'd still suspect the body mounts. You may need to shim them a bit to raise the center of the body.
bouncytruck 1972 K5
Old 10-19-2008, 10:05 AM   #9
Bentblazer
Bentblazer's Avatar
I'm a ways off before putting top on but also would like some closeup pics whenever some one has time.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 10-20-2008, 09:45 AM   #10
fun in dirt
Okay, I dug the hard top out of the shed Saturday & got it cleaned up (with a little help)! Are these the holes your taking about where the drip rail deflector should mount?
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 10-20-2008, 10:48 AM   #11
bouncytruck
SKINNY TIRES RULE!
Nope. Those holes are the mounting points for the hardware that holds the top in place. There are K5 specific sunvisor mounts that bolt to the windshield frame in the spot you are pointing at and then there is a mounting bolt that goes through the sunvisor mount into the top in the hole you're pointing at there.
bouncytruck 1972 K5
Old 10-20-2008, 04:14 PM   #12
65-72 chevytoys
65-72 chevytoys's Avatar
I need to do the same thing to mine when I get to it. I don't even have any weather stripping yet so I am subscribing for now.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 10-20-2008, 04:25 PM   #13
tdkosta
tdkosta's Avatar
Thank Bouncy for you input on this. I was wondering how the drip rail deflectors installed and where to buy them. A quick search on google yielded this http://www.classicparts.com/prodinfo...713&variation=. Has anyone ordered these or another set from a board vendor?
tdkosta is offline   Reply With Quote
Old 10-20-2008, 05:21 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like I need the deflector also . Do they really work? I have just redone my top and its getting $$$$ new glass,new windows and new bed rail seals so far and the list keeps getting longer..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-20-2008, 05:57 PM   #15
bouncytruck
SKINNY TIRES RULE!
Work is all relative. They probably work better than nothing, but they aren't great.
As for where to purchase them, I seriously doubt there is more than one manufacturer. There isn't enough Blazers still on the road to warrant more than one. Buy them from your favorite vendor.
bouncytruck 1972 K5
Old 10-20-2008, 06:29 PM   #16
knewman9n
knewman9n's Avatar
LMC has both.
knewman9n is offline   Reply With Quote
Old 10-20-2008, 07:06 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
mmmmmmmmmmmm wes would be my favorite vendor............wes
MEMBER #6377
Project "7DEUCE"
Old 10-20-2008, 07:13 PM   #18
bouncytruck
SKINNY TIRES RULE!
Yup, Wes! Use LMC for the pictures, Wes for the actual orders!
bouncytruck 1972 K5
Old 10-20-2008, 07:40 PM   #19
FRENCHBLUE72
PROJECT 7DEUCE
hey bouncy..what kinda pics do you draw all day?
MEMBER #6377
Project "7DEUCE"
Old 10-21-2008, 08:52 AM   #20
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's mine.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-21-2008, 09:34 AM   #21
bouncytruck
SKINNY TIRES RULE!
Originally Posted by BobbyK View Post
Here's mine.
Good call on the sealer before putting it on.. I'm not that smart...
bouncytruck 1972 K5
Old 10-21-2008, 09:55 AM   #22
fun in dirt
Thanks everbody for the info & to BobbyK for the installed pics.
This site is SOOOO helpful!
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 10-21-2008, 09:33 AM   #23
bouncytruck
SKINNY TIRES RULE!
I one of the owners of a graphic design firm, soon to be the sole owner - http://www.imageink.com
bouncytruck 1972 K5
Old 10-21-2008, 09:52 PM   #24
Bentblazer
Bentblazer's Avatar
What he said
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
Old 10-21-2008, 10:37 PM   #25
FRENCHBLUE72
PROJECT 7DEUCE
Thanks for the link bouncy...thread jack off sorry op
MEMBER #6377
Project "7DEUCE"
