11-25-2009, 10:22 PM | #1 |
Future gasser '57 chevy
Looking for ideas or suggestions to raise stock front axle 2 or 3 inches for that gasser look.
Thanks, |
11-25-2009, 10:36 PM | #2 |
One day...
Re: Future gasser '57 chevy
Man i love that body style!
11-26-2009, 12:12 AM | #3 |
THE TOY STORE
lower the leaf spring mounts. or go cheap and buy some blocks
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know. |
11-26-2009, 01:31 AM | #4 |
I am with you, cheapest way and easiest is to block the leafs... IMO
Brian
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
11-26-2009, 05:25 PM | #5 |
Generally not a good idea to use blocks on the front axle, lots of side loading from the steering.
11-26-2009, 06:37 PM | #6 |
One day...
Cant you do shackles too? Not too familiar with that setup but thought they have them...
11-26-2009, 08:55 PM | #7 |
I think he is right man, either way shackles or blocks will mess with the steering linkage. I am very new to this but sounds and looks like it would affect steering.
what about adding leafs? my 3/4 ton sits high and has just as beefy leafs in the back as it does in the front. either way sounds like a new pitman arm would be in order to correct steering issues.
09-18-2010, 07:04 PM | #8 |
11-27-2009, 01:27 AM | #9 |
I have car A.D.D.
Sorry, A square body guy chiming in on this one. You should be able to find some leaf packs that are the same width but are longer than your current ones. Then just bolt them in place. And, I agree that you would probably need to adjust your steering just like you would with any lift. But that is a way I have seen many vehicle types get some cheap, subtle lift.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
11-30-2009, 11:52 PM | #10 |
Work begins in stripping down to the bare bones!
Life is GREAT! |
12-02-2009, 12:05 AM | #11 |
Here is some pics inspiration.
I LOVE BURNOUTS:metal NO BOZO's |
12-02-2009, 09:24 PM | #12 |
You can buy a power steering conversion kit and just use the idler arm and steering arm. This shifts the connectin to the top of the King Pin. That will give you about 5". I also went to a later year steering box, Steve
12-03-2009, 03:46 AM | #13 |
that is just some cool **** to have the headers come through the inner fender wells...
oh!, and be high enough to see them...lol
12-05-2009, 02:05 PM | #14 |
I'm diggin' that black n' flamed GMC
12-05-2009, 03:03 PM | #15 |
yeah, me too! I think I found the inspirational photo that i needed.
12-10-2009, 01:12 AM | #16 |
Cleaned, wire brushed and painted frame.
Rebuilted front spindles with new kingpins and bushings. Upgraded to front disc brakes with five bolt pattern. Lots of work! |
12-31-2009, 12:06 AM | #17 |
Here are some pictures of Chevy 409 motor distained for future gasser '57.
Work in progress! |
12-31-2009, 05:06 PM | #18 |
Sweet motor!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
02-16-2010, 10:24 PM | #19 |
Slowed down for awhile because of the winter blues. I finally motivated myself to get going again. I installed a new power brake booster, master cylinder and brake lines. See new pictures!
Got rusted and lazy! |
02-16-2010, 10:39 PM | #20 |
I went to the Puyallup Swap Meet and found these goodies for my gasser project truck. Front tires are Coker 5.60x15 and rear tires are Firestone cheaters 8.20x15 with smoothie wheels and spider center caps. What do you think!
Big & Little look! |
05-06-2010, 10:49 PM | #21 |
This is the case of one step forward and two steps backwards! Discovered that the frame I was using had been a long bed frame and was shortened to a short bed frame and was cut wrong and the rear end and brackets were moved back 2.5 inches back from the stock location. Did not look right so I rounded up a second stock short bed frame - tore it down - had it sand blasted and repainted chasis black - and refitted with all the parts from the first frame. Progress is slow but moving forward.
Set backs are not fun! |
05-06-2010, 11:06 PM | #22 |
I located a donor 1957 chevy truck for the front fenders and hood - made arrangements to have the cab, fenders, hood, battery tray and other pieces sandblasted. I am very happy with the results. We have some rust issues on the inside and outside cab corners and lower fenders which we are going to address on the upcoming weeks.
Forward progress on the move! |
05-06-2010, 11:12 PM | #23 |
More pictures!
Starting to look like a plan! |
12-31-2009, 01:00 AM | #24 |
Love the engine. I've been toying with the idea of trying to find one for my truck.
Kim |
12-31-2009, 01:15 AM | #25 |
Didn't know Edlebrock made heads for 348-409. I've always liked them too. Were they ever available from the factory in pickups in 58-59?? I know the 348 was an option in the cars but we called the truck engines when I was a kid. Big trucks only?? I suspect the HP was a bit more than the 425 advertised too.
