12-04-2009, 08:17 PM | #1 |
How do I remove wax from black plastic?
I was waxing my truck the other day and I got wax on the black plastic fender wells. What can I remove it with?
72 Super Cheyenne lwb 4X4 Ocra / White 88 Chevy 1 ton Dumptruck 88 Chevy 1ton Flat bed 4X4 white |
12-04-2009, 08:35 PM | #2 |
Re: How do I remove wax from black plastic?
i have heard that a Mr. Clean magic Eraser takes wax off of plastic body moldings. try it and let us know
12-04-2009, 09:56 PM | #3 |
Tot Roddin'
Mr. Clean Magic Eraser's are awesome!!! I have used them for several different truck related projects, and they are a hidden gem.
As far as removing wax though... I haven't used them for this process. I'd be interested to know how they work. IIRC... Mother's has a cleaner/protectant (Back to Black, I think) that will restore the black to faded/waxed black trim.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-04-2009, 10:27 PM | #4 |
mini truck racer
X2 on the magic erasers .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-05-2009, 02:07 AM | #5 |
peanut butter with a tooth brush
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
12-05-2009, 04:38 PM | #6 |
Thanks for the info. I think my wife has some of the majic erasers. I will try that.
12-05-2009, 10:25 PM | #7 |
grease andwax remover a commonly sold product in autoparts stores
12-09-2009, 08:04 AM | #8 |
The One And Only !!!
Apply a little Fluid Film on a soft rag and wipe it on, It not only removes wax from black plastic/rubber but makes it look shiny new again.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
12-18-2009, 10:20 AM | #9 |
there is a product called Black Wow that works clean the wax off with soap first then use it
1971 LWB C10 - 5.3/350 1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet 1964 malibu ss - ls1/4l60 http://67-72chevytrucks.com/vboard/s...d.php?t=382403 |
01-18-2010, 04:36 PM | #10 |
If you use Armour All or whatever you use on the black trim first then wax your truck you can wipe it off .... no white stuff.
01-30-2010, 05:12 PM | #11 |
A trick I've used in the detail shops for years is get a small nylon detail (paint brush). Take electrical tape and wrap around the bristles so there is only about 1inch of brush hanging out of the bottom so its stiff and flat. Be sure surface is cool and wet with water. Get a mild all-purpose cleaner (409, simple green, ect) and mix 50/50 with water. Spray cleaner on a small area and softly and slowly rub the detail brush back and fourth onto the pours of the plastic. The small tight bristles will work into the wax and agitate it loose. Wipe dry with a clean cloth.
If you don't like Armor-All or dressings. There is a product called "Engine Blackout" made by Clean Cycle Products. That is put on with a sponge detail brush and will make it look new for about 3 months with regular washing. It's usually used for the black engines of Harleys but works well on plastic. You can usually find it at all Harley dealerships or online. About $15.00 a bottle and will last a good year or so. There is also a product called "Armidillo" used in the CHEVY dealerships for the fading plastics on the Avalanche models. It's a bit expensive but if you sneak back to the detail guys they may hook you up! Bring'em a 12 pack or something. GOOD LUCK!
JUST CUZ YOU POUR SYRUP ON S*%T DON'T MAKE IT PANCAKES! |
01-30-2010, 05:53 PM | #12 |
Redefining LowBudget
Hand sanitizer...it kicks AZZ on removing tree sap...I have pines in the yard
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-05-2010, 03:20 PM | #13 |
S.D.M.F.
Did u know armor all leaves a thin layer of something that u can only clean off with lacquer thinner? I learned that the other day at work. just sayin
1969 Chevy Longhorn 396/400 3/4 ton. 1991 Chevy Camaro RS 305/700r4 1978 Honda XL175 and XL350(the evil twin) 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc |
02-05-2010, 12:55 PM | #14 |
Moderator
goo-gone
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
02-14-2010, 01:09 PM | #15 |
'67 Chevy C-50
a white rubber pencil eraser the square kind you used to use in school, with some elbow grease takes it off of black trim
02-23-2010, 10:14 AM | #16 |
WD-40 on a rag removes dried on buffing compound residue and wax smears on flat black roof rack components, trim moldings, bumper covers, etc. A tooth brush used with WD-40 will get into the creases, cracks and corners.
