12-22-2009, 09:44 PM | #1 |
WTB: 16.5 x10" steel wheels
I am looking for a set of 16.5 x 10" wheels that will fit a 3/4 ton 4x4 80 chevy truck. I am looking for steel factory type wheels not spoke.
Thanks, Mark
72 Super Cheyenne lwb 4X4 Ocra / White 88 Chevy 1 ton Dumptruck 88 Chevy 1ton Flat bed 4X4 white |
12-23-2009, 05:30 AM | #2 |
thinair
Re: WTB: 16.5 x10" steel wheels
NOBODY has any of these??????
12-23-2009, 10:47 AM | #3 |
SWB 4x4 Collector
I have some, but am hanging onto them. They are getting harder to find in my area. I think a lot of them wound up crushed in my area, as I have had my set for about 11 years and don't stumble across them like I used to. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
12-27-2009, 10:48 PM | #4 |
Chevy Enthusiast
I have 5 for my truck, my step brother has 2 of them, and I just saw 2 on a ford pickup yesterday. They are really hard to find, if you find some don't let them go. Sorry none for sale.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
12-27-2009, 10:56 PM | #5 |
Chevy Enthusiast
Not sure if this will help but here is a thread about some from along time ago.
http://67-72chevytrucks.com/vboard/s...d.php?t=310694
12-30-2009, 09:08 AM | #6 |
The size is 16.5x9.75
Here is a thread with a link http://67-72chevytrucks.com/vboard/s...highlight=16.5
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-31-2009, 12:55 PM | #7 | |
12-30-2009, 05:40 PM | #8 |
the pollock
there in recent months have been a few sets posted for sale..
you might wanna search the forums a bit for them they r there and around because i ve personally had to back out on a set or two because my wife was going to kill me for buying them..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
01-03-2010, 01:48 AM | #9 |
I have a set of wagon wheels in 16.5, 2 have been blasted, 2 are somewhat chrome. If you cant find any others let me know.
Darren
67- 72 Parts collecter |
01-14-2010, 06:31 PM | #10 |
Thanks I have wagon wheels on it now that I am wanting to replace.
01-14-2010, 11:16 PM | #11 |
Just a bit of info for you . There were three different offsets made in that wheel . Not all will work on the front of a 3/4 ton 4x4 . They will rub if you get the ones with the most backspace . I think the other two will work . If you cant insert your finger between the wheel center and the rib in the outer hoop , they wont bolt onto the front .
Frank
Born and proudly residing in a Red State ! |
01-15-2010, 11:23 AM | #12 | |
01-29-2010, 06:14 PM | #13 |
Chevy Enthusiast
Hey, look what I found. Their probably a lot more than what you want to spend but hey their brand new. Check out the "Heavy Duty Truck - 20 Series"
http://www.stocktonwheel.com/4wd_offroad.htm
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) Last edited by 1985-GMC; 01-30-2010 at 12:00 AM. |
01-29-2010, 11:43 PM | #14 |
Jeez, $200 for a stock friggin wheel. I'll hit the junkyards to find them. That's just crazy.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-30-2010, 12:03 AM | #15 |
Chevy Enthusiast
Yeah its just a last resort. I'd start calling up junk yards, theirs bound to be some somewhere.
02-04-2010, 09:57 AM | #16 |
Wow that is expensive. I wonder what the 16 x 10" would look like. They are 155.00.
01-30-2010, 12:05 AM | #17 |
I had a set of 8s on my old truck, I sold them and can't remember to who. I woudn't mind having a set. Everytime I hit the yard here, that is one of the many things I look for.
01-30-2010, 03:57 AM | #18 |
will these work http://67-72chevytrucks.com/vboard/s...d.php?t=383798
70 SWB STEPSIDE 70 BLAZER 09 challenger |
01-30-2010, 09:31 AM | #19 |
They don't look like GMs, but I only ever had 1 set, that was couple years ago.
01-30-2010, 09:36 AM | #20 |
I`ve run the wider offset on all four corners.The only problem is mixing them up.The 9.75s were primarily a rear wheel for 2wds,which are deep offset, and the less offset are aftermarket for 4wds and utility.
The inner nubs are Ford wheels.The clip-type are`68-earlier,and the outer nubs in that listing are correct for`69-up GM. Just because these wheels aren`t blingy hoops doesn`t make them cheap.For a nice set figure sandblasting,powdercoating,and a set of cherry hubcaps=not cheap,just more classy.When those blingy hoops are dull,damaged,or just played out these steelies are just breaking in.You can blast and paint them forever.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-30-2010 at 09:38 AM. |
01-30-2010, 12:48 PM | #21 | |
Chevy Enthusiast
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) Last edited by 1985-GMC; 01-30-2010 at 12:50 PM. |
01-30-2010, 04:00 PM | #22 |
Disagree if you want.Just like GM went from clips to outer nubs,Ford went from inner to outer nubs.My point was GM never used inner nubs.
01-30-2010, 09:46 PM | #23 |
Chevy Enthusiast
OK I took what your were saying as "ford only had the inner nubs", that's all.
09-07-2011, 07:54 PM | #24 |
Chevy Enthusiast
Did you ever find any of these? There's some on craigslist: http://houston.craigslist.org/pts/2555976255.html
Or if you look up "camper special" some of the trucks still have them on the rear, this one looks like the might be: http://dallas.craigslist.org/ndf/cto/2582951779.html
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) Last edited by 1985-GMC; 09-07-2011 at 08:05 PM. |
