Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-25-2010, 11:42 AM   #1
J_PEPIN87
J_PEPIN87's Avatar
Spark plugs and carb?
Im almost finish putting together my 427bb and i have two questions.the first one,wat kind of spark plugs should i use?any part numbers.the engine is a 427 bored 30 over, 049 oval ports with 2.190/1.88 valves.trw dome top pistons @10 to 10.5 compresion,comp cams 292 magnum cam.the second one, im thinkin of goin with a proform 850 carb.summit part#67201 do yal think this is a good carb to go with?is it good size, too small or too big?
J_PEPIN87 is offline   Reply With Quote
Old 01-25-2010, 09:32 PM   #2
POPO1984
POPO1984's Avatar
Re: Spark plugs and carb?
damn bro nice set up. Did you build it.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 01-25-2010, 11:15 PM   #3
J_PEPIN87
J_PEPIN87's Avatar
Yeah I put it together and I had craig caulk da all the machine work.you've probably heard of him right?
Old 01-26-2010, 01:08 AM   #4
gastrader35
HOARDING SPECIALIST
gastrader35's Avatar
I would go with a holley street hp 950 it should work very good. I think the ngk race plugs work very good for $2.99 each. I have seen nothing but bad luck with the pro form carbs last one i seen had the boosters in crooked. Just my opinion stay away from the pro form carb. Good plug to start with if you use the ngk is 5673-7
gastrader35 is offline   Reply With Quote
Old 01-26-2010, 02:19 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I use NGKs on a 10:1 compression ratio ZZ4. They work great!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-26-2010, 10:45 AM   #6
POPO1984
POPO1984's Avatar
Yeah Craig has done some heads for me on my 08 silvy. if i dont buy a crate engine i will probably get him to rebuild my current one.
South Houston
Old 01-26-2010, 10:59 AM   #7
J_PEPIN87
J_PEPIN87's Avatar
Originally Posted by popo1984 View Post
yeah craig has done some heads for me on my 08 silvy. If i dont buy a crate engine i will probably get him to rebuild my current one.
he also did my heads no porting though.
Old 01-26-2010, 10:52 AM   #8
J_PEPIN87
J_PEPIN87's Avatar
Thanks a lot guys for the responses.anybody else have any opinions on the proform carbs?anybody running delco rapidfires?
Old 01-26-2010, 11:35 AM   #9
toms84ss
I've heard a lot of bad things about the Pro Form carbs. Stick with a name brand, you get what you pay for.
toms84ss is offline   Reply With Quote
Old 01-26-2010, 01:17 PM   #10
J_PEPIN87
J_PEPIN87's Avatar
Originally Posted by toms84ss View Post
i've heard a lot of bad things about the pro form carbs. Stick with a name brand, you get what you pay for.
wow i thought proform carbs were pretty good i guess i was wrong.wat about quickfuel carbs?
Old 01-26-2010, 11:55 PM   #11
djracer
djracer's Avatar
buy a holley hp750. I don't like the quick fuels either. I might be able to get you a deal on one if you decide to go that way.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-27-2010, 12:17 PM   #12
team39763
I've read a few threads lately about pro-form and it sounds like their quality control is in the pooper. What about getting a custom carb?...like Braswell or ProSystems. I hear they can tune the fuel curve for your combo. That's what I wanted to go with, but for now I chose to keep messing with my current 750DP so I could learn a little bit on my own.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 01-27-2010, 12:35 PM   #13
J_PEPIN87
J_PEPIN87's Avatar
Well after hearing all this stuff about proform i think im going with a holley 4150 hp carb.still unecided on the plugs though.
