Raising up after flip kit?
I'm in between on which method to lower the rear of the truck. I have a 4" drop kit with the front spring hanger and shackles. If I take out the overload spring I may get a 1/2" more. If I go the flip kit I could relocate the rear spring shackle hanger lower by about an inch decreasing the drop or get a 4x4 rear spring hanger to decrease the 6" drop of a flip kit. Does this sound right, or has anyone tried this?
Re: Raising up after flip kit?
dam should have went with the flip kit first
6.0 powered square
I'd say get some stock 2wd hangers and shackles, and add a flip, but first I'd say remove a leaf or 2
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Squarebody Aficionado
flaming i know you have done this before what leafs did you remove from your spring pack? i lowered the front of my truck more and i have to even out the back, i know you said it was alright to leave at least 3 and i still have 5 but the first ones i took out were in the order the were mounted. should i take one from the top(longer) leafs?
It followed me home?
You might want to ask lolife about the 4wd hanger, I think thats the best way to raise it up 1" or so with the flip. Removing leafs is an easy cheap way of doing it depending on how much motor you have, if you have some power you are going to get a lot of axle wrap removing leafs. You can also get a lift shackle but I think the tallest they make are 1/2-1" this is what I did for my blazer but its still a little low.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
6.0 powered square
the leafs I removed were was the two that are shorter than then ones with eyelets and the over load
with flip kit 3 leafs no over load ![]() 5 leafs no over load ![]()
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 03-10-2010 at 09:37 PM. |
flaming, did you have any axle wrap when you had only 3 leafs in the rear?
6.0 powered square
didn't feel any
GM Addicted
what do you mean by axle wrap?? my truck only has 3 leafs as well without a flip kit.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
I really hate wet sanding!
![]() Join Date: Dec 2008
axle wrap is when u mash the go pedal, the rear diff will try to spin as power is applied, when it breaks traction, u will have "wheel hop", caused by this condition as the rear springs try to bring the axle back to it's normal position. I have never seen it happen, but I suppose in severe cases, you could break a u joint, rear yoke, or even the leaves themselves.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
yup. if you get on it you'll feel it vibrate irratically and it's a terrible feeling. you'll think the rearend came apart. lol. you wont want to do it again thats for sure.
where can you find taller hangers?
Posted via Mobile Device |
At the body shop.
4x4 hanger
" That didnt make it any newer " " Dont antique the equipment " |
You can flip the 2wd rear hanger to put the shackle pointed down. It was good for about 1"-1.5" lift on my blazer.
