03-13-2010, 02:53 AM | #1 |
Gauge Upgrade!
Finelly got a few pics of the gauges, Sorry there's not many of the complete install, my batteries went dead about an hour into it (nephews playing with the camera etc...)
Anyhow, here's what I came out with. Their all Autometer Ultra-lite II's, These things looked awsome when lit up so I paid a few extra bucks to order them, the alumnium bezel is a major pain to round out yourself if you don't have access to a good machine shop. I'd say all in all it was a pretty easy upgrade, I did alot of reading on here especially from past installs and ordered everything I could, I.E. Wiring harness, bezel, etc... I added a shift light but decided to put it on the dash corner rather than the column like orginally planned, Right now i'm using the column shift so I didn't like the idea of putting it there, I'll eventually have a floor shifter installed, so I may move it down there later. Here's what I got so far... First day Disassembly, We done this over 2 days, first day i'd say we spent about 2 hours fitting everything into the alumnium bezel and factory dash inserts. then about 8 hours the next day finishing the fitting, wiring, and changing out and running wires needed to sending units... Speedo, temp, and oil pressure. completely gutted... Here's when we finished everything in the bezel. and after trimming out the plastic bezel Unfortunately this is where my camera went dead, so the rest of the pics are just of the finished product... snapped this with my phone before I stuck the shift light to the dash with some double sided tape. Here's a few in the dark...
Joe 1957 Chevy 3100 Stepside |
03-13-2010, 03:27 AM | #2 |
Re: Gauge Upgrade!
Wow! nice improvement! those look really good!
How much did the entire setup cost?
With enough time and money, you can do anything Quoted from my father 1976 C-10 Project |
03-13-2010, 03:50 AM | #3 |
Re: Gauge Upgrade!
Total was alittle over 1K, but I bought a few extras I didn't have to have, like the alumnium inserts, and the wiring kit, the kit makes it a TON easier, but it costs ya for it, the kit was 137 bucks from Jegs, and the alumnium pieces were from LMC.
Ahh, I left the shift light out... it was in that amount as well, that's another $120 you can take out, it's the stage 2 digital.
Joe 1957 Chevy 3100 Stepside Last edited by Tezjoe84; 03-13-2010 at 04:07 AM. |
03-13-2010, 03:53 AM | #4 |
Re: Gauge Upgrade!
Aw wow, far beyond my price range for gauges atm haha.
Well for a little over 1k, they really look worth it. I was looking at that set awhile back too.
03-14-2010, 06:07 PM | #5 |
Re: Gauge Upgrade!
NIIIIIICE!!!!! THEY LOOK BAD a$$$$$
just look around, I bought some couple of weeks back they are not the same as the ones shown here but they are the black ones, I got electri speedometer( i have a 5.3/4l60e) tach,oil,temp,fuel,and volts they were already in a 80-87 bezel, for 190 buck... just keep looking ... you might just get lucky
ONCE YOU GO LS, YOU NEVER WANT LESS!! |
03-14-2010, 08:38 PM | #6 | |
Re: Gauge Upgrade!
03-14-2010, 08:39 PM | #7 |
Re: Gauge Upgrade!
yeah 190 bucks is a GREAT deal, Grats man!
03-13-2010, 08:40 AM | #8 |
Re: Gauge Upgrade!
seven series if your just after the gauges you can get them for 660 or so. Thats what i paid
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
03-13-2010, 02:29 PM | #9 |
Re: Gauge Upgrade!
Yea I think if I just bought the gauges themselves it would have been somewhere around $780.00. You can get the regular Pro-comps alittle cheaper than these, I paid more because their the II series with the LED backlighting.
03-13-2010, 03:28 PM | #10 |
Re: Gauge Upgrade!
Ohh I see, thanks Cherub. I really only was going for the gauges lol
03-13-2010, 08:49 AM | #11 |
Re: Gauge Upgrade!
that is bad a$$ man! nice job... how is the line of sight and angle of the gauges? i'm also going this route but was planning on mounting them on the backside so they would be angled up. i think this looks a bit cleaner though.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
03-13-2010, 02:26 PM | #12 | |
Re: Gauge Upgrade!
Yea, the angle is kinda bad,that would probably be my only complaint... but it depends on your size, i'm 6'1, and the angle does kinda suck... they make angled bevel's that go behind the gauges to angle them up some, I may go this route down the road, but for now I can live with looking down alittle. My dad's alittle shorter than me and when he sat in the seat he said he could see them fine. I thought for a long time about the recessed install as well, in the end I just liked the look of the flush mount look.
03-20-2010, 10:50 AM | #13 | |
Re: Gauge Upgrade!
I love what you have done and since my dash had been hacked up by a past owner I am going to go the way you did. Do you have a photo of the back side of the face plate by chance. I would love to see exactly how they are mounted and how they fit in relation to the stock dash cover. Thanks a ton.
07 Chev 2500HD Classic Project Ranch Hand, Hauling A$$ since 1973 I was told this Project had a L-72 427 425HP, It did not. It does have a 427 block and parts from various 427 motors. It will end up with a nice strong 454 in the end. It has not been run for 20+ years Frame up restoration started2/15/2010 |
03-20-2010, 07:38 PM | #14 | |
Re: Gauge Upgrade!
Unfortunately I don't have any other pics of the install, my batteries went down in my camera, and I didn't really have time, or a vehicle to run to town for more. The gauges come with mounting brackets to mount flush, so it was reall easy. Here's a write-up Jeff did when he installed his flush mounted gauges. 73-87.com surface mount install Hope this helps ya out!
03-20-2010, 10:29 PM | #15 |
Re: Gauge Upgrade!
Yep, their mounted to the aluminum plate, this is the easiest way to install I believe, but as far as visibility I think recessing the gauges behind the bezel would be alot better.
were the holes in the plate the right size or did you have to open them up for the gauges? Thanks
03-13-2010, 04:49 PM | #16 |
Re: Gauge Upgrade!
Awesome!!
03-13-2010, 05:31 PM | #17 |
Re: Gauge Upgrade!
Looks awesome Joe! That is a night and day improvement. I really like the LED backlighting. That is the ones I was looking at, but with the black face.
03-13-2010, 06:50 PM | #18 |
Re: Gauge Upgrade!
I hear ya John, I'd definately recommend these to anyone doing a street car/truck. these things look awsome and are easy to read at night. i've always wanted to do an all autometer cluster... and once I seen this series, I had to go ahead with it.
03-15-2010, 10:43 AM | #19 |
chevy truck fan
Re: Gauge Upgrade!
tezjoe84,
by chance do you have any pics of the wiring, iam doing the same thing on my '72 & i would like ot see a shot from the back.... thanks!! rodstored-72 |
03-17-2010, 07:09 AM | #20 | |
Re: Gauge Upgrade!
I used the Wiring kit from Jegs and it was a breeze, just read it first, look over the kit and familiarize yourself with it, it's step by step and had a excellent diagram for the factory wires, all color coded. The kit itself is color coded as well as all labled per wire... Great kit if you have alittle extra to spend on it.
03-18-2010, 05:19 PM | #21 |
Re: Gauge Upgrade!
Wow, that looks very good, sure would like to do that to my 71 someday!! I take it there all electric?
71 chevy cheyenne lwb http://s321.photobucket.com/albums/n..._tab_my_albums Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote! |
03-15-2010, 09:36 PM | #22 |
Re: Gauge Upgrade!
damm that looks sweet
03-20-2010, 08:47 PM | #23 |
Re: Gauge Upgrade!
So Joe, what idiot lights do you lose from the speedo and fuel gauge?
03-20-2010, 11:19 PM | #24 | |
Re: Gauge Upgrade!
I have a High beam blue LED right between my tach and speedo.
