04-27-2010, 09:12 AM | #1 |
How much cam is too much cam for power brakes
I'm talking about a 454 application this time but when is a cam too big to run power brakes without a vacuum canister?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
04-27-2010, 02:11 PM | #2 |
Re: How much cam is too much cam for power brakes
Not sure if this will help you or not but I was running a cam with 243/250 duration at .050 on a 108 intake center and a 111 lsa. I was able to run power brakes. But I only have 347cis..
I think the thing you need to look at is how much overlap the cam has and where the valve events are against static compression (leading to DCR). There is a lot that determines vacum at idle/cruise. I'm assuming you will be running a hyd cam for maintenece reasons? Flat or roller? The lobe profiles will differ.. If you give me some more details I can put in it performance trends and give you an idea of vacum at idle. It may not be spot on, but might help a little.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 04-27-2010 at 02:13 PM. |
04-27-2010, 02:21 PM | #3 |
Not sure but overlap and duration determine it. Roller cams, esp hyd i believe can take more then FT. not sure when you can not, all depends on the eng combo (Heads, carb)
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
04-27-2010, 02:20 PM | #4 |
Its a lunati 60212.
Hydraulic roller, lopey idle. High performance street cam. Likes upgraded intake, carburetor and exhaust system. Needs 2800 RPM or better stall speed converter, 9.75:1 compression ratio and 3.55-3.73 rear gears. Advertised Duration (Int/Exh): 282/290 Duration @ .050 (Int/Exh): 231/239 Gross Valve Lift (Int/Exh): .600/.600 LSA/ICL: 110/106 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 2200-5800 Includes: Cam Only Part Number: 60212
04-27-2010, 02:47 PM | #5 | |
On a budget like Fred Sanford
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
04-27-2010, 02:32 PM | #6 |
Heads are 781 oval ports with 2.19 1.88 valves. It should be around 10 to 1 comp.
04-27-2010, 08:16 PM | #7 |
Yeah, that cam is rather small for a 454ci in regards to idle vacum issues. You have 66* of overlap at .006 and 15* at .050..
In my 347 I have 24.5* at .050 and close to the same 66* you have at .006 with 107ci less..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
04-27-2010, 08:38 PM | #8 |
Thanks Guys.
04-28-2010, 12:25 AM | #9 |
Registered Truck Offender
I agree with ripdog here Kevin, but keep in mind I don't know jack about the bigblocks and what is too much. That exhaust valve closing is going to be key in if it makes enough vacuum for PB or not. Could always advance the cam a little to get that exhaust closed a tad earlier and start building vacuum earlier too. Should help if it were marginal.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
04-28-2010, 12:34 PM | #10 |
Good to go DJ. And that's a very good cam choice
Shawn
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! |
