06-25-2010, 07:35 AM | #1 |
72 GMC
2008 SILVERADO Power Door Locks
Anyone know how to disable the "automatic" locking and unlocking of the doors without disabling the power door locks themselves ?
Thanks Kel |
06-25-2010, 07:36 AM | #2 |
72 GMC
Re: 2008 SILVERADO Power Door Locks
Sorry
wrong forum |
06-25-2010, 04:32 PM | #3 |
mmoved for you
03-20-2014, 09:07 PM | #4 |
Where did this post get moved to??
Thanks !!
It's Not Rust, It's Patina!! 1967 C 20 Large Window, 700R4, 283, Tilt, PS, PB.....A Rusty But Trusty Gas Hog 2008 Silverado LTZ 1500 4x4 |
03-21-2014, 11:09 AM | #5 |
I agree that you can change it in the DIC to either out of park or rolling, but is there anyway to make it so they don't automatically lock?
On my 04 that was an option but on my 12 it doesn't seem to be. I don't want to be running kids to school and having the doors locked.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
03-21-2014, 11:18 AM | #6 |
A quick google search found this TSB from GM. Looks like a dealer can do it.....
Subject: Disabling Auto Door Locks Models: 2005-2011 Cadillac Escalade, Escalade ESV, Escalade EXT 2005-2011 Chevrolet Avalanche, Silverado, Silverado Classic, Suburban, Tahoe 2005-2011 GMC Sierra, Sierra Classic, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI. Condition/Concern: Some customers may comment that they are unable to override the automatic door locking feature. In prior model years, customers were able to select "Doors Lock Manually" from the DIC. However, starting in the 2005 model year, this selection was removed. Recommendation/Instructions: Since the 2005 model year, all BCM's (Body Control Modules) are programmed from the factory to lock all doors when the transmission is shifted into gear or vehicle speed is greater than 8 mph (13 km/h). There is no option to disable the auto door locks from the factory, but if an owner wishes to have the auto door locks disabled the following procedure can be performed by the dealership: Note: Use the appropriate procedure below (either 1 or 2) for the Year and Model vehicle you are working. 1. Use the following procedure to disable the auto door locks on the models listed below: 2007-2011 Cadillac Escalade, Escalade ESV, Escalade EXT 2007-2011 Chevrolet Avalanche, Silverado (new body style), Suburban, Tahoe 2007-2011 GMC Sierra (new body style), Yukon, Yukon Denali, Yukon XL, Yukon Denali XL A. Reprogram the BCM with updated calibrations currently available in Tis2Web. When viewing the "Calibration Selection" screen in Tis2Web, select "locking" (should be highlighted in Red) and pick the calibration listed as "(Per Customer Request Only) Auto door locks off, option no longer in DIC". Note: For the 2010 and 2011 Model year the calibrations are no longer selectable in TIS2WEB and Techline Customer Support (800-828-XXXX) must be contacted to obtain the calibrations. B. After reprogramming the BCM, use the DIC controls (RPO UK3) to scroll through the personalization settings to the "Auto Door Lock" feature. There will be two different settings: "Lock with speed" or "Lock in gear". You will notice there is NO new setting but also there will be no "check This PI was superseded to update model years. Please discard PIT3189N. marks" next to any of the settings. This means the auto door lock feature is disabled. If there is a "check mark" next to one of the "Auto Door Lock" selections then the only way to remove the "check mark" is to scroll to "Factory Settings" and select "Restore", this will remove the "check mark" thus disabling the "Auto Door Lock" feature. Note: Please keep in mind that if "Factory Settings Restored" is selected it will change all of the other personalization settings back to the factory settings and they will need to be reset back to the owner's preferences. On vehicles without the DIC controls, once the BCM is reprogrammed with the new calibration the "Auto Door Locks" will be disabled and there is no way to turn the Auto Door Locks back on unless the BCM is reprogrammed with the previous calibration. 2. Use the following procedure to disable the auto door locks on the models listed below: 2006 Cadillac Escalade, Escalade ESV, Escalade EXT 2006 Chevrolet Avalanche, Suburban, Tahoe 2006-2007 Chevrolet Silverado Classic (old body style) 2006-2007 GMC Sierra Classic (old body style) 2006 GMC Yukon, Yukon Denali, Yukon XL, Yukon Denali XL Note: NO new calibrations are available for the 2005 models or vehicles with manual transmissions. A. Reprogram the BCM with updated calibrations currently available in Tis2Web. When at the "Calibration Selection" screen in Tis2Web select "locking" (should be highlighted in Red) and pick the calibration listed "(Per customer request only) Auto Door Lock option ENABLED on DIC". B. After reprogramming the BCM, vehicles with Steering Wheel Controls (RPO UK3) can use the controls to scroll through the personalization setting to the "Auto Door Lock" feature. There will be a new "Manual" selection now available to choose, along with the two previous selections "In Gear" and "With Speed". C. After reprogramming the BCM, vehicles without Steering Wheel Controls will need to enter the door lock programming mode procedure located in section 2 of the owner's manual. Once in the programming mode press the lock side of the driver's power door lock switch, you will hear either one, two or NO chimes. One chime indicates you are in Setting 1 (lock in gear), Two chimes you are in Setting 2 (lock with speed) and NO chimes you are in Setting 3 (Manual). Continue to press the door lock switch to scroll through the 3 different selections until you hear the desired setting and then exit the programming mode by turning the ignition key on.
06-26-2010, 09:15 AM | #7 |
72 GMC
Exactly what I was looking for.
Thank you. |
06-28-2010, 10:39 PM | #8 |
My 2008 door locks "disabled" themselves on the same day, actually the actuators both went bad at the same time. And I just had to have those keyless handles. DOH. both were fixed on warranty and they didn't give me any crap about the handles.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
07-03-2010, 05:53 PM | #9 |
72 GMC
I still love the fact that if I open the door with the key, the alarm goes off because I locked it with the remote fob !!!!
08-04-2010, 01:44 PM | #10 |
I believe there are options in the "DIC" (Driver Information Center) display for power locks.
2008 NNBS ECSB Cocoa Metallic Texas Edition McGaughy's 5/7 Drop: 2" Drop Spindles, 2" Coil Relocators, 1" Drop Springs, 7" Flip Kit, 2050 Shocks, Shock Extenders, McGaughy's Helper Bags / 24x10 U2-55 wheels on Kumho 275/30/24's / DiabloSport Predator Diablo Tune / DDM Raptor HID's / Debadged / Lamin-Xed Headlights (Tint), Taillights (Gunsmoke) and Fog Lights (Tint) / Extang Tri-Fold Tonneau Cover My previous trucks: My '84 SWB My Tahoe Limited |
08-06-2010, 08:37 AM | #11 |
Old member
That's correct. You can cut it off set to lock when taking it out of park or as I set mine once you get going.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
