11-23-2010, 12:15 AM | #1 |
Punched Holes in Tranny Hump
My '64 Fenderside has two punched holes in the upper portion of the transmission hump similar to the holes depicted in the attached photo. It seems like i have seen these holes punched in other trucks on this forum. Why would these holes be there? Will I regret patching them?
11-23-2010, 01:45 AM | #2 |
1961 crewcab
Re: Punched Holes in Tranny Hump
A guess , but they might be to geat at those 2 upper bolts easier bellhousing/motor.
those 2 are the hardest to get a good bite on.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-23-2010, 03:40 AM | #3 |
theoretically one doesn't need to undo those bolts on a std trans in the truck as everything in the flywheel clutch area is accessible through the bottom of the b/housing and if it is an a/t a 24" ext and a 9/16 impact flex socket will get up in there nicely
ron |
11-23-2010, 07:16 PM | #4 |
If you have a stock bellhousing (cast iron and open on the bottom) there is no real need for those holes. If you have an aluminum full-circle bellhousing, you might want to leave them there.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-23-2010, 07:35 PM | #5 |
Im thinking it looks like a car 4 speed setup. Maybe it had 2 different car 4 speed setups over time.
11-23-2010, 09:30 PM | #6 |
One foot in front of the other
Bullet holes?
12-09-2010, 07:04 PM | #7 |
Who Me?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
12-09-2010, 04:49 PM | #8 |
My 64 gmc has the same holes, they are drane holes for aftermarket ac underdash unit. There are 2 drane tubes one on each side of unit. MIKE
12-09-2010, 05:46 PM | #9 |
x2. My 64 (the one I had back in high school) had a dealer installed under-dash a/c set-up. It had 2 drain tubes that were poked through the floor carpet & dumped condensate out the tunnel.
12-09-2010, 07:13 PM | #10 |
I would plug them with rubber grommets. Then you can keep the cold air out and be able to access the bolts if needed.
12-09-2010, 07:20 PM | #11 |
Senior Enthusiast
That makes a lot of sense. That's how they installed aftermarket smog controls on old engines back in the early 60's. A hole would be drilled in the intake manifold (while it was bolted on the engine!), and then a lead hose fitting was pushed into the hole. The valve cover and air cleaner didn't need a drill because a fine precision hole (?) could be pounded in with a punch and hammer looking just like the ones in the floor pan photo. Hoses were attached and the car was now smog legal. Of course the engine failed shortly thereafter because of all the filings dropped in the engine and all the new found vacuum leaks.
12-10-2010, 08:53 PM | #12 |
I still have the ac unit in storeage. I could get the make and model # if you want to check it further.
