Rottenwood Garage Member
Front wheel center bore too big issue...what to do?
Ive searched for a thread I have read but I cant find it. As we all know the front drums on all these 6 lug trucks require such a large "center bore" on the rims we are limited on the wheels we can run. Im not interested at this time in doing a major running gear conversion but I have seen threads on milling the wheels OR changing the front brake drums and bearings over to those from a 6 lug car or van. I have read the thread but I cant find it.
I really want to run some 17, 18, or 20's in a 6 lug Torq Thrust style rim. Thread links, ideas or help would be appreciated.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
60-66 Nut
Re: Front wheel center bore too big issue...what to do?
It has been my understanding that most if not all aftermarket wheels had a center bore large enough to fit the hubs on these older trucks. I could be wrong though on some of the newer larger diameter wheels. I'm not aware of any hubs and drums that can be swapped onto the '63-'70 spindles that will have a smaller hub register.
#3 | |
Ttt
you can always have them machined to fit. the hubs on my trailer are a little to big for the set of rallye wheels that I have , so I am just going to chuck them up and machine the hubs down a bit to fit
ron |
![]() Join Date: Oct 2006
Most wheel manufactures make there wheels with the bigger hub hole and use "hub centrict"rings that allow the wheels to fit the newer smaller hole hub this saves them money and invantory.
The catch comes when the wheels are made for specifc applications. Newer 6 lug Chevy/ GMC use the smallar hub bore and require a medium off set wheel of up to +20MM,ours take a standard or zero off set or a reversed (deep dish) off set in some cases. What type and size of wheel were you looking for?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Resistance is Futile
If you have disc's up front they fit just fine.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
