Old 04-30-2011, 12:15 PM   #1
bowtieboy1993
62' rearend change to 5X5
hello i am new to the forum, and am currently working on restoring my 1962 Chevy short wide. i have already changed the front K-member to a 1978 for the 5X5 bolt pattern. and was wondering if there was anyway to keep my original rear end because it is a 10 bolt with a 3.90 gear ratio. I think i can redrill the axles and brake drums, but was wondering if there were any aftermarket axles or lockers/spools available. any help will be appreciated.
bowtieboy1993 is offline   Reply With Quote
Old 04-30-2011, 01:01 PM   #2
Clyde65
Clyde65's Avatar
Re: 62' rearend change to 5X5
you can talk to Moser axles and they will tell you what they have and or what they can do for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-30-2011, 07:17 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: 62' rearend change to 5X5
Ahhhh.. Just put a Ford 9" hiney under her!
Tell the the fellas ya packing a 9!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-30-2011, 09:38 PM   #4
scotts62
One day...
scotts62's Avatar
Yep i have a ferd 9" out of a lincoln versi with factory disc brakes.
Scott
93 crew cab build
Project 62
Old 04-30-2011, 10:10 PM   #5
1Bad62Pro/Street
Those are kinda rare hard to find ones. Seen one at the Charlotte car show once for sale.
Guy wanted to much. Way to much.
Mine is out of a 57 Ford Wagon.
No need to narrow it with the wide hides.
Perfect length.
One legger for now. 3.70 Gear.
Old 04-30-2011, 11:00 PM   #6
scotts62
One day...
scotts62's Avatar
Got mine for $150 and went through it and put a locker with 3.73's in. Cant wait to try em out
Scott
93 crew cab build
Project 62
Old 05-02-2011, 10:16 PM   #7
1Bad62Pro/Street
Yank that 3.73 out Scott and slip on a 4.56 gear with strange axles.
The Detroit Locker will hook like a son of a gun.
My dad has it in his rambler american.
Tacking 3 grand at 55mph.... And still roast the tires when you nail it at 55mph.
Beep Beep.... Beep Beep... Heard that rambler go beep beep.
Yea.... I'm a gear head.
More like LOWPOE62.
Old 05-01-2011, 12:20 AM   #8
Captainfab
60-66 Nut
As far as I know there isn't any aftermarket support for the HO55 rear ends. You may be able to get aftermarket axles made, but you might check with someone like Moser as Clyde65 mentioned. It all depends on what you need in a rear end. If you need a posi and plan on beating on it, then you might consider upgrading to a 12 bolt truck differential. If your main concern is just converting to the 5x5 wheel bolt pattern, then I would just have the axles plugged and drilled to the 5x5 pattern. You could try a '71 and up drum for fit, but you may have to drill the original drums too.
Old 05-02-2011, 10:03 PM   #9
bowtieboy1993
alrite thnx for the input guys, its sounding alot easier and cheaper to just find a rear end out of a 73-87.
Old 05-04-2011, 04:44 PM   #10
aspiringthomas
aspiringthomas's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=462050
Check this out if you want to put in a 73/87 rearend.
Thanks Jeff.
aspiringthomas is offline   Reply With Quote
10 bolt, 1962, 5x5, chevy, rear end
