Speaker Pods for Lower Door
One of the members on here (Justpball) has a build thread and built some pods to go on his lower doors. Im trying to build some myself now and was wondering what the best way to wire the speaker up is, i know ill have to probally drill holes but i want it to be clean and not just have wires hanging so how would i go about doing it right. I tried to PM Jpball about it but his inbox was full lol. Id like to know where he put the bolts through to hold it on the door, maybe he will see this thread. Thanks for the help guys if anyone has speakers wired up in their doors and can show me some pictures on how they ran the wire it would be great.
Heres a picture of the pods he made, i think there cool. |
Re: Speaker Pods for Lower Door
Did some reasearch and found theses http://www.keepitcleanwiring.com/cat...-Loom--(1-Pair) Anyone use these or something similar, how did they do and does anyone have some pics with these installed. BTW i forget to mention these pods are for an 83 C10.
#3 | |
Life, Be In It.....
![]() Join Date: Oct 2003
I bought a pair of them and wanted to put them in my doors for power windows and speakers. There is one problem that prevented me from using them, and that is the ID of the braided hose is tiny. Barely enough room to run wires, let alone speaker wire.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
Thanks for the info jugernot, is the rubber part im gonna need #11 on this page? http://www.lmctruck.com/icatalog/cc/full.aspx?Page=17 I don’t want order the wrong thing. One other thing about running the wires from the door to the cab, I see how it goes into the cab but where is it routed to inside? I know there’s not just a hole on the inside, can someone get me some pictures of the inside of the cab or describe to me how I need to run the wire. Wish one of our four Chevy’s here had electric windows or something so I could look at them but unfortunately they don’t
![]() Also do i have to use rivets or will sheet metal screws work to connect the rubber boot to the door and cab? Last edited by BoredJoe; 06-28-2011 at 12:50 AM. |
what are you talking about? Tiny? its like 1/2" diameter i will post pic
Life, Be In It.....
Well, when I get the parts back from the shop I will happily show you. No room for electric window wires and good speaker wire. If you want decent sound from good speakers you need to run a thicker wire!
Those look real nice. Why can't you run the wires through your power window bellows? Thats what I would try and do. as far as attaching you can do it without exterior screws. You can add a variety of plastic fasteners to the door. then add the corresponding one to the panel. they make all kinds and we sell all kinds. Metal and Plastic. I think screws would ruin the looks but if you have to maybe just 2 in the lower corners
I don't have power windows in mine wish I did. As far as fastening it justpball said he put four bolts that stuck out the back of the pod the heads were fiberglassed over to hold them and then he drilled four holes in the door, took the door panels off reached in and put nuts on from the inside so no bolts are seen. I'd rather not drill holes but I don't know of any fasteners that would allow it to mount flush without drilling holes. Any ideas on were to drill for wires since I don't have power windows or locks. CAn anyone take a picture of where there powerwindow wires run from door to cab. Thanks. Can't wait to build them, ill be happy if mine turn out half as nice as his.
Posted via Mobile Device |
here you go. the boot is on the same CL as the door switch. You have to take the door off to install. At least we do. I thought the pic was your truck. The only way to install is some real good tape. slamming the door would cause it to fall off I imagine if not quality tape. They make a round insert. its small used on mid 60's Impalas that is used to install door panels. You could just use four and then attach the clips to the panel. its only four holes.I would use some tape also on it. thats what i would do. if you want to use the hoffman door piece you posted I have two good used ones that you can have for the shipping cost. they are almost like new. Otherwise I would just purchase a rubber one.
Thanks mike, Ill prob look for some rubber boots like the picture but if I can't find any around here I may message you about the ones you have. I think I'm gonna attach it to the door with four bolts I can always cover the holes with a carpet piece if I don't like the pods. Picture helped a lot now I gotta go buy some fiberglass
mine a 71 hade 5/16th holes in the doors and the area near the light door switch..
I oped them up added a grommit. and was done with it.. no need to add that big door to pillar boot.. for one wire.. |
Well i got the speaker rings cut out of MDF and hopfully can start building the form to fiberglass over soon, been busy working though. Ill post up pictures if these turn out ok, ive never fiberglassed anything so they may end up like crap lol. Wish me luck. Im also kinda worried about where i can drill four holes in the door to mount them i dont wanna hit anything inside and mess my doors up.
#13 | |
Life, Be In It.....
There is the link to the ariticle http://forums.sonicelectronix.com/th...ng-Kick-Panels
#14 | |
![]() ![]() If you are building fiberglass or any other here is the company we purchase our material from and have used them for years and they have great info to start and learn. i highly reccomend them. you will learn a lot. good luck http://www.freemansupply.com/ Last edited by mbgmike; 07-04-2011 at 11:49 AM. |
#15 |
I like to keep things stock looking. it seemed to me he wanted to do this the right way
#16 |
#17 |
#18 |
78K & 79C Jimmys
usally they hide better and they only show when the door is open
but some trucks just have a rubber plug in that hole may wana add something after that you need more space(elect door lock)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
