09-29-2011, 04:25 PM | #1 |
ls1 oil priming
Just thinking the other day that my 5.3 motor has been sitting in my project for almost 2 years and will probably be sitting a few more months before I fire it, so I was wondering if there was anyway to prime the oiling system before starting it again.
09-29-2011, 08:51 PM | #2 |
Re: ls1 oil priming
I have seen an article about this. Maybe in Hotrod?
Someone used a pail, electric drill running a SBC oil pump with a hose tied into a fitting into the block (I think) Maybe try a search on google |
09-30-2011, 10:56 PM | #3 |
Hollister Road Co.
Re: ls1 oil priming
GM uses something similar to the mityvac setup
http://www.mityvac.com/pages/products_fee.asp |
09-30-2011, 11:28 PM | #4 |
Re: ls1 oil priming
I just poured some Marvel Mystery in each cylinder and turned the crank by hand. Mine started up fine and has run great ever since.
67 5.3L Build |
10-01-2011, 04:03 PM | #5 |
meowMEOWmeowMEOW
Re: ls1 oil priming
a little wd40 in each cylinder, crank with the plugs out (no compression) to get a little prime, and you should be good to go. My engine sat for a while at the wrecker, then again on my engine stand for nearly 5-6 months. Fired up with one little *puff* to get the wd burned out...right on the first try.
I did check to make sure that there was no rust in the cylinders BEFORE all this, but the wd helped keep things easy.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
