rims
i am curious on what rims will fit 1 ton running gear ive got 16.5s but there not the best to drop tire presure due to popping the bead. but dose any one know the smallest rim i can run?
Redneck Customs Bumpers, IA
Re: rims
you can run 15's if you grind your calipers up front and get the proper offset, otherwise you can go with 16's without any modifications
Overkill is under rated, Redneck Customs Truck Club Hudson, IA "Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's "Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP '00 ex-cab Silverado 4x4 DD I hate red trucks but you can't tell by looking at what I own |
Re: rims
I run 15's with alot of grinding to the front calipers. 16's are direct fit and can be aired down nicely.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Re: rims
Depends on the backspace of the wheels. I know guys running customs with 2" backspace that didn't grind at all and others running standard 4" backspace that ground a bunch.
#5 | |
Chevys Kick A$$
Re: rims
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
![]() Join Date: May 2007
Re: rims
17" rims give you a lot of tire choices.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
