Old 10-06-2011, 09:33 PM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
'06 HD Straight Axle Conversion Build Pics...
Hey All....
Once again my long time annoying buddy, Joe, has got me wasting my time on more of his BS builds...this time once again on his weak a$$ truck (always give'n crap about it)
Anyway, should'a bought a Diesel, but whatever, 6.0 it is !!
When he got this truck a while ago, we lifted it using a PC kit.
After that came an airlocker, which took its toll on the halfshafts..three to be exact !! Then snapped a carrier mount...then lost a wheel on the highway !!!
So after a long time of slowly collecting parts...here we are !!!
ORD supplies the kit, Super Duty witll spring it, and a 3/4 ton Dodge AMM axle will carry it....
Here goes nuthin.....
Lets get this sucker on the lift, shall we ?
Some left over carnage:
What a joke...
More clearance without this hanging Torsion Xmember....
We loosened everything up, and lowered the truck's stock suspension onto a pallet:
Front complete 6" Procomp list will be for sale, BTW .... complete with arms, steering, pitman arm, etc....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-06-2011, 09:37 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: '06 HD Straight Axle Conversion Build Pics...
Good luck with it. That's a sweet truck too. Even if it does have a 6.0 in it.
Ryan
1969 Chevy milk truck
Old 10-06-2011, 09:58 PM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I know it is ... it's my good friend Joe the kinda friend you grew up getting in trouble with...(ya, that kinda friend )
I would take that 6.0 for my '63 C-10 any day !!!
But, he still should of got a DuraMax !!
Although a future Cummins swap is up in the air.....
Wait a minute, that would mean more of "Joe" in my shop !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-06-2011, 09:47 PM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Here's the Dodge Axle....Another good thing about running this axel, is the Chevy ABS sensors are same, and will plug right into the Dodge axle !! This kit is intended for an older Ford axle, which already has 36" pad centers...
Gonna have to plasma off all the stock coil and fourlink mounts....
Stock mounts removed:
(sorry for the small, dark pictures...dont feel like redoing it all....)
Front hooks are temporarily removed to install front hangers....
If you notice, the crossmember was removed (even though the kit states that it doesn't need to be removed...DO NOT REMOVE exact words) ... I'm gonna fab up a much cleaner one later !!
Rear hanger mock up ... bolt on as well, but I am gonna burn it in for extra insurance. It only bolts to the inner wall of frame:
Stupid Duty Springs in:
CoilOver/Shock mounts locate to stock upper a-arm mounts and stock shock mount...
Slight trimming required...
More soon !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-06-2011, 10:31 PM   #5
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Got me hook. You wanna come help me with mine next? lol j/k I'm gathering info to prep my my 1/2 ton 2wd to SAS silverado.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-07-2011, 02:47 AM   #6
Dieselwrencher
A cummins in that truck would be awesome!
Ryan
Old 10-11-2011, 09:42 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Back with a few more pics.....
Welded up the mounts for a little added strength:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-11-2011, 09:56 AM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Axle is finally prepped and sanded:
Now, the only tuff part about running this Dodge axle was getting the drivers side leaf spring pad to sit correctly.
Pass side...no brainer:
The springs have to be set at a 36" pad center....So this DS places the pad part way up onto the center casting....With a little patience, I made it happen !!
First we trimmed off the pad so it sits level:
Then we had to slightly grind away part of the casted in bumpstop contact pad:
Once we had the pad over far enough (it didn't take much really, only about 3/16" of material had to be removed) it was time to drill for the u bolt...
Simple notch gave clearance for u-bolt:
Before we drilled, we pulled the diff cover and checked to be sure it was in fact a big chunk of casting....
The kit supplied us with 3" axle ubolts, and one larger one (the one used). This axle requires 3 1/2" which are coming today....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-11-2011, 11:05 AM   #9
Dieselwrencher
Very nice work! I'm sure that was nerve wracking drilling into the housing!
Ryan
Old 10-11-2011, 02:27 PM   #10
snj8198
snj8198's Avatar
Good info sir. What length springs and rate are you using? And what shocks did you decide to use? By the perches it looks like you plan on running duels straight up. If I ever decided to purchase a new body style GM I would jump right into a SAS.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 10-11-2011, 06:14 PM   #11
kSStamp0182
LSX addict
kSStamp0182's Avatar
subscribed. i plan on buying a duramax like this asap, and the IFS will be the FIRST thing to go!
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 10-12-2011, 12:01 PM   #12
jeremy zander
jeremy zander's Avatar
Very nice..OK I am next for the swap and mine is a dmax..
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 10-12-2011, 05:14 PM   #13
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Looking badass so far. The drilling part looks scary but it looks like it turned out great. Keep up the good work and good luck with the rest of it
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-13-2011, 10:49 AM   #14
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
We are using stock '99 up SuperDuty springs. I'm not a big fan of running 20 shocks per corner for some kind of 'look'. I recommended to him to just run two lightly valved shocks....
Good idea guys !!!
Thanks .... here are some more from last night:
I patch up the frame in the area where the stock crossmember was removed:
Next I turned to welding the pads on....letting the axle cool after each pass:
Used some temporary ubolts for mock up...I jsut had to see what this sucker was gonna look like.....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-13-2011, 10:52 AM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
So far I and the owner are liking it.
Acording to the kit...hanger and Super duty spring provide an equivilant to a 6" lift...but it looks more closer to 8"
Next will be some paint...correct u-bolts, then move on to steering !!!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-13-2011, 11:04 AM   #16
kSStamp0182
LSX addict
looks damn good!!!
i have no idea what this cost, but this is something i'll be looking into on mine!
http://spyntec.com/02-08_dodge_spyntec_overview/
Old 10-13-2011, 01:31 PM   #17
snj8198
snj8198's Avatar
So the plan is to see what you get for lift in the front then match the rear?
Steve
Old 10-13-2011, 02:10 PM   #18
Dieselwrencher
It looks awesome! Nice welds too btw!
Ryan
Old 10-13-2011, 04:19 PM   #19
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Now that is just darn right awesome! Just the way the General should have done it the first time. The only place IFS belongs is on ATV’s and little trucks like Toyota Tacomas.
Good work Chief!
Looking forward to the final product!
DirtyLarry is offline   Reply With Quote
Old 10-13-2011, 07:28 PM   #20
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks guys....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-14-2011, 02:01 AM   #21
y5mgisi
Second Chance Program
y5mgisi's Avatar
Damnit thats bad ass!!!
Quick question, How long are the super duty springs?
y5mgisi is offline   Reply With Quote
Old 10-14-2011, 02:08 AM   #22
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks ... coming along !
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 11-10-2011, 07:09 PM   #23
Solego
Dr. Frankentruck's Monster
Solego's Avatar
I love Chevy trucks. But this is why I bought a Jeep. I don't have the talent to do that.
I'm not prejudiced, I hate everyone.
Project SLOMO
http://67-72chevytrucks.com/vboard/s...d.php?t=430494
Solego is offline   Reply With Quote
Old 11-10-2011, 08:32 PM   #24
47thriftmaster
47thriftmaster's Avatar
Work looks great, should be a lot of fun when finished. I did my '06 a few years back, but did coil overs in all 4 corners rather then leafs. It's a blast and he won't have to worry about replacing the CV shafts all the time. Here's a quick pic.
47thriftmaster is offline   Reply With Quote
Old 12-17-2011, 10:43 AM   #25
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looks good man, what axle you running ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
