I've got grease on my mind.
Lowered Leaf Spring Pics and Updates 67-72
Just picked up a 69 CST longbed with rear leafs. Looking at getting lowered springs, dropped shakles, or/and revering the spring eyes.
Let's see what you got. How about some pictures of your leaf spring drop, 3", 4", 5" and so on. If you could include any issues, tire size, and ride quality that would be great! Here are the stats; 285/70/15 BFG's about 18" from center of axle to fender lip Looks like 2 of 3 springs removed, (PO said he took out the short lower spring and included it with the truck) Suspension does not seem flex much when you jump in the bed but it is a very smooth ride. Not too smooth or too rough. Could be from the tall, soft tires. Last edited by Hard Luck; 03-02-2012 at 03:19 AM. |
Re: Lowered Leaf Spring Pics and Updates 67-72
flip kit, 1'' block., 1 leaf pulled ,2'' drop shackles, kyb gas adjust shocks on custom made mounts to run full length shocks ,cpp c notch, small section of bed floor raised over diff, cpp rear sway bar , it does hit the bump stops on really hard bumps but the ride is good due to a leaf being pulled rear tires are a 225/75/15 like 26'' tall and tucking
*bump*
Here she is almost a year later. 3" drop front springs, 4" drop rear leafs, 245/70/17 all the way around.
Looking good brother
Posted via Mobile Device |
Thanks Mike!
Tags |
drop kit, leaf spring, lowering, slammed |
