Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-14-2012, 11:28 PM   #1
Spot1984
Widest Rear Tire With Factory 12 Bolt?
I have the rear lowered 6 inches. I have the factory 1970 12 bolt (C Clip elminator) I am going to mini-tub the girl. What is the widest rear tire I can go with? Also what backspace would I need? I'm jammed up here on this boys! Some pics would be helpful too. Ooo factory springs and trailing arms. Thanks!
1970 Chevy C10 shortbox- 454
1970 Chevy Nova- 383
1987 Grand National
Spot1984 is offline   Reply With Quote
Old 06-15-2012, 10:56 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Widest Rear Tire With Factory 12 Bolt?
I asked this, and ended up having to just go and measure; are you asking for the widest tire on a normal rim, or the widest rim AND tire you can stuff in there?
If you want to go as wide as you can, you'll need to have custom wheels made or ordered.
I squeezed a 15x12 with a M/T drag radial in 325. Assuming the 12 bolt is stock width, that will be about the biggest you can go (a slightly larger diameter rim might get you a tiny bit more width inside, but not much)... it requires about an 8.5" backspacing, which is deeper than some companies will do, although you can get them. It makes rear brakes a pain though, depending on the rim size (I run 15s) you may have to modify your brakes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-15-2012, 01:48 PM   #3
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
We run a 31x18.5" hoosier on a minitub and smaller diameter springs.
ProStreet68SB is offline   Reply With Quote
Old 06-15-2012, 08:18 PM   #4
Spot1984
Prostreet68 what backspace are you runnin? I was wondering if 15x12 with 7.5 backspace and 325 tire would fit?
1987 Grand National
Old 11-04-2012, 12:55 PM   #5
1moretoy
Did you have to narrow the frame?
1moretoy is offline   Reply With Quote
Old 11-07-2012, 08:13 AM   #6
spill
Where u get dose rear ralley wheels
spill is offline   Reply With Quote
Old 11-07-2012, 09:41 AM   #7
ProStreet68SB
Nope. Cut the bed back to the frame and run straight spring instead of a factory style.beehive.
Widened factory wheels.
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
Old 06-15-2012, 10:16 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not sure if your slightly newer fleetsides are wider or not. I've got eh trailing arm suspension w/ jeep springs which are a tad wider.
If I would have gone with a 7.5" bs, the tire would rub into the outside of the fender.
Old 06-15-2012, 10:40 PM   #9
74 stepside
74 stepside's Avatar
315/60/15 MT drag radial on 15x10 with 5" bs on stock width 12 bolt. No tubbing needed.
74 stepside is offline   Reply With Quote
Old 06-16-2012, 01:30 AM   #10
ProStreet68SB
We're running a non tapered, we've alway assumed they were Jeep springs.
And we're running 8.75inches of backspacing.
Old 06-16-2012, 10:15 AM   #11
djracer
djracer's Avatar
I had 12.5 wide sportsman pro's on this old 71 with an off the shelf Centerline Telestar wheel.
This truck was not that low you would need a little more back spacing but not a ton.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-16-2012, 04:16 PM   #12
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Here is link to a pic i posted last year for some one asking the same kind of question. I was lazy and didn't want to find the pic and upload again lol
14 or 14.5 wide wheels with 15 inch wide tires and all stock susp. and stock width rearend that is what it had when i bought it.
http://67-72chevytrucks.com/vboard/s...12&postcount=8
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 11-01-2012, 08:05 PM   #13
spill
I have a 15x12 6"back space will it work on a 1965 chevy truck ,what is the lest back space u can have with a15x12 wheel
Old 11-01-2012, 11:05 PM   #14
Captainfab
60-66 Nut
Is your truck a stepside or a fleetside?
Old 11-02-2012, 05:59 PM   #15
spill
Old 11-01-2012, 11:46 PM   #16
spill
Fleetside
Old 11-02-2012, 12:19 AM   #17
hotrod 80
mini truck racer
hotrod 80's Avatar
Welcome to the forum
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-02-2012, 12:27 AM   #18
djracer
djracer's Avatar
Fleetside
What Year?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 11-02-2012, 09:33 PM   #19
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
My plan is replacing the 12 bolt with a stronger rear (Dana 60 or 9.5" 14 bolt) and narrow it by 1.5-2" per side w/mini tubs and 15x12's...then 315/60-15's will fit easily.
but for now...its factory 12 bolt with new Eaton posi and 3.73 gears
they're 15x10", 4.5"b.s., with MT ET Street radials in 315/60-15
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-02-2012, 10:57 PM   #20
Captainfab
60-66 Nut
Is your 12 bolt the original 62" wide or is it the wider '63.5" width used from late '70 on up? Are you willing to widen the inner wheel wells? What size tire are you wanting to run?
Old 11-02-2012, 11:19 PM   #21
spill
15"29x15.5 , later 70&up
Old 11-08-2012, 09:26 AM   #22
bigboybodry
bigboybodry's Avatar
My rear tires are a 29/15.50 15 sportsman or a 31 10.5w on a custom Holeshot 16" rim with a 10" backspace. I ordered a new set of factoy rear wheel tubs and welded them to my old ones. My frame has not been moved and I ran the factory style spring with this setup.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 03-14-2013, 09:03 PM   #23
sleeper69
do you guys think ill be able to run 295/50/15 with a 5.5 bs, on a 69 short bed fleetside (factory tubs) and have everything clear?
sleeper69 is offline   Reply With Quote
Old 03-14-2013, 11:04 PM   #24
spill
Old 03-15-2013, 06:33 PM   #25
sleeper69
factory 12bolt and 15 by 10 rims with either a 5 or a 5.5 bs
i seem to remember that there is around 12 or 13 in the factory tubs. the truck is in the shop being painted right now and i dont have it here to measure
