Starting 6.0 swap, ls6 intake ??
Ok guys I'm attempting my first engine build/ swap. I got a 6.0 from my old work truck, Also came across a 2wd 4l80e last year, My plan is just a reliable street motor, Basically good heads and cam, looking to do car style intake, and headers.
My first question is. What all do I need for put a ls2/ls6 intake on the 6L. I know the accessory drive need to be changed, or altered, but what else do I need? Thanks for any input Posted via Mobile Device
Hows it goin Eh! ![]() 1985 Chevrolet C10 Silverado SWB-395 Stroker 490hp,700R4 12 bolt 3:73 posi,inferno red crystal pearl coat with black ralleystripes,custom leather seats, carbon fiber gauges 2005 silverado 1500 ecsb, Z71, 33x12.5 dick cepek http://www.cardomain.com/id/Kearney Stephen |
Re: Starting 6.0 swap, ls6 intake ??
You'll need an ls1 fuel rail and injectors too as well as the injector plugs in the harness will need to be changed. The fuel inlet on the rail will need to be bent slightly to clear one of the coils. The throttle body will also hit the upper radiator hose if you keep the truck accessories.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#3 | |
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#4 | |
meowMEOWmeowMEOW
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#5 | |
#6 | |
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
bought it on e-bay.
#8 | |
![]() Join Date: Jan 2012
Here are a few pics: ![]() ![]() Good luck with your conversion.
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
You have a couple of options.....
1. You can rig it with just a camaro/trans am ls water pump and space the pulley (risk bad harmonics and leaks/burning a water pump) 2. You can get all camaro/trans am front cover accessories (water pump, ps pump, alt, idler, crank pulley etc.) and run ls1/2 intake, tb and fuel rails. 3. Stick with the truck stuff and run a trailblazer ss intake manifold. Great tq and hp, much better alternative than the stock vortec truck manifold. Much cheaper and you can keep all of the factory truck accessories and wiring.
66 SWB Stepside: Project C-O6 06 ZO6 MSM 6spd 562/520rw N/A 06 Caddy CTS The Daily 07 Hayabusa - absolute chaos |
Bigger throttle body and different runners mainly. You will notice ~15-18rwhp/tq difference between stock and the tbss.
Thanks for the info guys
I found this ls6 manifold at Texas speed shop is this a good deal? http://www.texas-speed.com/p-3612-gm...-assembly.aspx Posted via Mobile Device
You can find LS6 intakes for under $400 shipped on tech regularly.
LS2's are 1/2 that price. |
Do they usually come with throttle body fuel rails and injectors? For under 400?
I was looking at a ls2 but can't find a dbc throttle body for a ls2 Posted via Mobile Device
#15 |
Yes. You just have to keep your eyes open, I've seen 2-3 come up in the past month or so.
Me personally, I'd put a TBSS intake on it and be done. Cheaper and you don't have to mess with the accy drive. |
#16 |
you need to go with the truck style manifold. alot better bottom end torque
#17 |
I got all kinds of torque...lol.
#18 |
Are the fuel rails on the ls6 intake for a return or returnless fuel system?
#19 |
Do I need the ls6 valley cover and steam lines? I finally have the motor in the truck but the Intake won't sit down all the way
#20 |
I think you just need to change the bolts out with some button head allen bolts..
#21 |
Do you have a picture of a "button head bolt". I had my 5.3 stripped down with no steam lines on and my ls6 intake wouldn't go down all the way.
#22 | |
![]() Join Date: Jul 2009
http://www.ebay.com/itm/LS1-LS2-LS6-...80b718&vxp=mtr |
#23 |
I'm using the LS3 intake and L92 heads on my LQ4. Pace Performance has the intake for a couple hundred less than the LS6. I think it was Hot Rod that did a test of most of the CNC ported L92/LS3 heads and a stock set. They all flowed about the same and there wasn't a big difference between any of them. The stock L92 heads are under $1000. The magazines show 500 plus HP with a decent cam. You would have to change the connectors for the injectors.
It is also easy to stroke. Everybody makes a kit since the 6.0 is a 4" bore. With a .030 bore you end up with a 408. I'm just going to burn money on my LQ4 and do the stroked 408, L92 Heads, LS3 intake and the MSD Atomic LS EFI system. It's not cheap but eliminates the wiring mess. It's going to end up costing more than the truck. Posted via Mobile Device |
#24 |
meowMEOWmeowMEOW
What trans are you gonna run? The atomic needs it own trans controller doesn't it?
#25 |
4L80 or 85. I exchanged email last week and they sent out a notice to dealers. They'll have DBW and transmission control this summer. Both TCI and Painless have standalone transmission controls. Both support paddle shifting and stuff like that.
Here is the LS3 intake with a cable throttle body; http://paceperformance.com/i-8185604...iv-intake.html Posted via Mobile Device |
