Old 03-13-2013, 11:18 PM   #1
Mackula02
1950 Chevy truck- types of Bench seats
I have a 1950 chevy truck.. I want a full Bench seat.... anyone have replaced their old seat with a newer one from a current vehicle?
Mackula02 is offline   Reply With Quote
Old 03-15-2013, 01:34 PM   #2
lazypineapple
lazypineapple's Avatar
Re: 1950 Chevy truck- types of Bench seats
there alot of threads on the board about seats for our truck.
its not a full bench but i use a 2nd row astro van seat
i see your in texas i have this on for sale $40.
lazypineapple is offline   Reply With Quote
Old 03-25-2013, 03:44 PM   #3
Mackula02
LazyPineApple,
thanks But I am looking for a full bench seat...
thanks
Old 03-25-2013, 05:47 PM   #4
lazypineapple
I have the original seat springs from my 52 also, for sale too. from my left overs
Old 02-06-2017, 10:34 AM   #5
lazypineapple
Sold
Old 02-06-2017, 12:57 PM   #6
vintovka
vintovka's Avatar
I chose to keep the original bench seat. The bottom required some spring replacement and frame repairs. The frame was broken in two places and i "sistered" steel channel along bottom to reinforce. I did consider buckets but removing the original seat base (that is attached to the floor of the cab) might weaken it. The original seat coupled with a tilt column may limit my beer consumption.
The original cab floor seems a weak point anyway especially on my frame swap with a k10. I added a full 2x4 steel channel under/across the front and square tubing at the rear between chassis and cab. The latter doubles as a seat belt anchor,
vintovka is offline   Reply With Quote
Old 09-05-2018, 05:17 PM   #7
sandys
hello lazy pineapple picked a seat from a astro van like you did, yours looks good, can help me and tell me where you went and got your leather kit from I am having problems finding one . I could really use your help. thanks your truck looks good
sandys is offline   Reply With Quote
Old 03-25-2013, 08:20 PM   #8
Root2812
Root2812's Avatar
Originally Posted by Mackula02 View Post
LazyPineApple,
thanks
1991 Astro mini van. Cheap and plentiful.
I got this one and plan on installing it once it warms up. I like it bacause it was cheap, close to the right width, and no head rests so when reupolstered is should look good.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 03-25-2013, 08:23 PM   #9
Root2812
Root2812's Avatar
LazyPineApple,
thanks
I got this one and plan on installing it once it warms up outside. I like it because it was cheap, close to the right width, and no head rests so when reupolstered is should look good. I paid $20 for it.
My 1950 Chevy build
Old 03-31-2013, 07:51 PM   #10
Mackula02
Thanks for sharing Root2812
Old 04-23-2013, 11:38 PM   #11
Mackula02
Root 2812,
when you prepare to install seat, i would like to see how you create the brackets..
Old 04-23-2013, 11:54 PM   #12
parkwood
parkwood's Avatar
even though this seat is in a '55 i'm showing it so you'll see the style.. It's a Wiseguys seat and fit a mounted nice... i'm sure they make one for an early '50's truck
parkwood is offline   Reply With Quote
Old 04-24-2013, 12:55 AM   #13
Root2812
Root2812's Avatar
Root 2812,
Sure thing. I just picked up a welder so once I get some time to get the metal for the brackets I'll get started. This endless winter has slowed me down a bit.
My 1950 Chevy build
Old 05-01-2013, 04:20 PM   #14
1lo67
1lo67's Avatar
Do you know measurements of the astro seat? wondering how much difference in it and a full size bench.
1lo67 is offline   Reply With Quote
Old 05-02-2013, 09:26 AM   #15
lazypineapple
It is 54" wide
Old 09-05-2018, 04:59 PM   #16
sandys
trying to send lazy pineapple a meassage and ask him where he bought that leather kit for his astro van seat. see how good it fit, I just picked one up same seat. please get back to me don't know where to buy the leather kit. thanks sandy
Old 03-25-2013, 06:18 PM   #17
D-man313
D-man313's Avatar
Mid 90s fullsize gm
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 03-31-2013, 07:54 PM   #18
Mackula02
D-Man 313, it's not to wide for this truck is it?
thanks!
Old 03-25-2013, 08:44 PM   #19
mr48chev
mr48chev's Avatar
That should fit pretty nicely but unless the truck is chopped I'd vote for having the stock redone by someone who knows what he is doing. Over the past 40 years I've probably had ten different seats in my 48 since I chopped it an nothing was as comfortable as the stock seat that Bobby Russel in Waco redid for me the week before the Street Rod Nationals in Tulsa in 1973. With that seat I could jump in the truck an make a 400 mile road trip and feel ready for more. The seat I have in it now looks nice in the truck and fits great but is more uncomfortable than sitting on a sheet of plywood.
Note: Any seat you use in these trucks has to have a very thin and upright lean back unless you are very short and thin yourself. The problem with most late model seats is that they leave no room in the cab of AD trucks when they are in the truck. The mini van seats usually have rather thin and upright backs and have bases that are fairly easy to modify to fit our trucks.
My ongoing truck projects:
Old 03-31-2013, 07:32 PM   #20
H.I.
H.I.'s Avatar
Here's a picture of my early 90s Chevy full size truck bench seat. It fits perfect. It's pretty comfortable. I just threw a Mexican blanket over it for now. But my bud Cato Custom Upholstery is recovering it for me.
I wanted to keep the factory seat surround. So I cut 2"-3" out of the horizontal pieces and welded them back together. That was it fit down inside perfect. You sit lower down in the cab than the stock seat but its so much better. More leg room etc.
[IMG][/IMG]
H.I. 1953 Chevy 1/2-ton 5 window with 235 ci straight 6, dual fenton headers, dual offy intake with 2x1s. 3" dropped axle w 3 leafs removed front, 3" blocks in rear with 2 leafs removed, T5 Camaro/S10 hybrid transmission
H.I. is offline   Reply With Quote
Old 03-31-2013, 07:33 PM   #21
H.I.
H.I.'s Avatar
Here's a pic of the seat down in the stock seat surround.
[IMG][/IMG]
Old 03-31-2013, 07:49 PM   #22
Mackula02
Ok, Cool thanks for a response....
Old 03-31-2013, 10:39 PM   #23
D-man313
D-man313's Avatar
No, have one in my 49, its close to the doors, but doesnt hit. More comfort, more leg room, its adjustable back and forth for different sized drivers. Cheap from the junkyard to.
Old 04-24-2013, 06:19 AM   #24
coralhead
coralhead's Avatar
Here is my stock '50 seat that was professionally rebuilt and covered.
Original seats can look good and fit right in without any mods.
coralhead is offline   Reply With Quote
Old 04-24-2013, 03:13 PM   #25
98layinframe
98layinframe's Avatar
The stock seats look nice when recovered.. but man do they take up the space! I'm 5'11" tall and pretty small at 170lbs and with a stock seat and stock steering wheel these trucks feel tiny inside.
My vote is for a early 90's chevy full size seat. The mounting brackets sit nice and flat on the floor (factory seat riser removed) they have a nice skinny back so it can be slid back for lots of leg room. Even with a 2" chop top its comfortable to sit height wise, if ya want more space the side mounts are extremely easy to shorten up to 3-4"
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
