upper control arm hitting spindle
well im installing a mcgaudys disc brake kit with 2 1/2 drop spindles on a 1970 c10. The problem i am having is my upper control arm is hitting the top of the drop spindle. I've read people saying trim the upper control arm a little so it doesnt interfere but i feel like the upper ball joint isnt seating correctly in the spindle. Now i measured the widest part of the taper on the ball joint and it was around .708". I measured the widest part of the taper on the spindle and it was around .735". does this sound correct?
The ball joints im using are MOOG Part # K6024 These are the spindles : http://www.summitracing.com/parts/mm...del/c10-pickup heres some pics of the issue |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: upper control arm hitting spindle
Do you have any weight on the suspension yet?
i had the jack under the lower arm from when i installed the coil spring
Watch out for your cornhole !
![]() Join Date: Jun 2003
When you drop the full weight of the truck down, the suspension should cycle down enough to open up the gap between spindle and control arm.
Posted via Mobile Device |
I have the same spindles and I just didn't like when I jacked up the front I couldn't turn the wheels... so I fixed it by trimming the upper control a tad bit and smoothing out the top of the spindle.
Now that I have a lift in the garage, I'm happy I did this. My truck is on the lift a lot and it would be a pain if the front spindles were hitting check it out in my photo build thread. post#34 http://67-72chevytrucks.com/vboard/s...8&postcount=34
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
![]() Join Date: Nov 2011
got the same problem with my 70' - just installed my disc brake kit (McGuaghy's also) and took it down to have front end aligned- mechanic says it calls for .5 degrees camber but the best he can do is 1.9 degrees both sides- have you encountered the same issue?
