04-18-2013, 09:59 PM | #1 |
56 chevy
Hi guys im new to the site, just wanted to share my new project i started. Its a 56 stepside, i have a long list of mods planned. I started with building a completely new frame. tci mustang 2 frontend with air ride and 2 inch dropped spindles, i have a 598ci supercharged big block waiting to go in it. bought somw 20x15 wheels for the back and some 29x18x20 tires. just getting started with. ant and all opinions welcomed.
04-18-2013, 10:06 PM | #2 |
Re: 56 chevy
A few more pics. any advice would be appreciated.
04-19-2013, 01:09 AM | #3 |
Re: 56 chevy
Welcome.
Sounds like a real sweet build. Kim |
04-19-2013, 08:39 AM | #4 |
Re: 56 chevy
Nice build you have going on, but do you think it will have enough power?
I guess a blown 598 big block will be OK, LOL. What kind of engine is it, BTW? |
04-19-2013, 04:56 PM | #5 |
Re: 56 chevy
Thanks guys. Im hoping for a real nice turn out. and u can never have enough power. The motors a gm based dart tall deck block. 4.6 bore and 4.5 stroke dart 345 CNC heads. Currently running a psi blower but not sure if its gonna fit under the hood. I don't wanna cut up the hood. I moved the motor back about 4 inches and as low as I could get it down while still running a 10 quart pan.
Posted via Mobile Device |
04-19-2013, 09:34 PM | #6 |
Re: 56 chevy
cool!
04-24-2013, 09:44 AM | #7 |
Re: 56 chevy
Got my rear tires mounted up yesterday, so it looks like im a start narrowing my rear end housing this weekend after i finish my resecced firewall.
04-24-2013, 09:59 AM | #8 |
Re: 56 chevy
Those look nice.
How wide are they? Kim |
04-24-2013, 10:26 AM | #9 |
Re: 56 chevy
thanks Kim cant wait to roll them under the truck, they are 29x18x20.
04-24-2013, 11:07 PM | #10 |
Re: 56 chevy
Cool build . The Merc 525 is just for test fit then, untill big brother shows up?
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
04-24-2013, 11:19 PM | #11 | |
Re: 56 chevy
04-25-2013, 06:20 PM | #12 |
Re: 56 chevy
Those engines were so dam rich out of the box. Just incase they got put in some big turd that was lugging them all the time . Merc didnt want to be giving warranty due to leanout . Time spent reflashing to get them right would be painfull i have to think.
The intake would look cool under the hood tho.
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 Last edited by 6BT 56; 04-25-2013 at 06:20 PM. Reason: I cant spell |
04-25-2013, 06:44 PM | #13 |
Re: 56 chevy
They it would look good, but I don't have the computers, and I don't want to use the crank trigger and coil packs that came on the motor. I need to find a computer that I can use with a msd distributer.
04-25-2013, 07:31 PM | #14 |
Re: 56 chevy
Wow. Awesome build. Those rear meats will have no problem being turned over by that small 598......haha
Cool ride!
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
04-25-2013, 11:24 PM | #15 |
Re: 56 chevy
Your truck is looking great. Nice choice on the wheels and tire too.Good luck the rest of the way.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
04-26-2013, 11:02 AM | #16 |
Re: 56 chevy
Thanks im very excited about this build, I bought a 56 truck when i was 14 yrs old and was doing a frame off on it with a camero front clip. I had the cab and fenders blasted and all the sheet metal work completed. Had plans to prime it the day hurricane Katrina hit and devastated us. after the bare metal truck sat in salt water for two weeks it trashed.
04-26-2013, 10:57 AM | #17 |
Re: 56 chevy
Thanks, yeah that lil motor will be between 750 and 800hp if i leave it naturally asperated, and over 100hp if i super charge it, witch i propbaly will, I run a psi blown 598 in my boat and it makes 1246hp. so should be a fun ride.
04-25-2013, 11:38 PM | #18 |
Re: 56 chevy
Great looking. wheels what make are they?
Good lookin project Posted via Mobile Device |
04-26-2013, 11:11 AM | #19 |
Re: 56 chevy
04-26-2013, 11:25 AM | #20 |
Re: 56 chevy
04-26-2013, 12:16 PM | #21 |
Re: 56 chevy
with that there truck you will pass everything including the police and gas stations .................well maybe not the gas stations !!!!!! lol
04-26-2013, 12:22 PM | #22 |
Re: 56 chevy
Nice build subscribed
04-29-2013, 05:23 PM | #23 |
Re: 56 chevy
Got a lil bit done on the truck this weekend. Mounted the wheels on a telesoping jig to help determing the rearend width, and cut the wheel opening in the bed and made the templates foe the wheel tubs.
04-29-2013, 05:29 PM | #24 |
Re: 56 chevy
I also finished fabing up the firewall and tacked it all in place. I followed the shape of the motor pretty tight to allow room for the a/c unit under the dash. im also sealing off the cowl vent and removing the steel under the dash for the vent to allow more room to get the a/c tucked in tighter. the firewall is also tall enough so i have enough room to pull the distributor out if i ever need too.
04-29-2013, 09:59 PM | #25 |
Re: 56 chevy
Looking good.
Have you got any pics from under the dash of the area where you removed the metal? I may do that to mine for room also. Kim |
