05-02-2013, 03:37 PM | #1 |
exhaust manifolds?
what clears the mounts on a 71 c-10 with the dirty dingo adjustable slider mounts? the factor truck manifolds did not clear
05-02-2013, 04:09 PM | #2 |
Re: exhaust manifolds?
2010+ Camaro SS manifolds will..
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-02-2013, 07:40 PM | #3 |
so http://www.ebay.com/itm/Pacesetter-E...fddba0&vxp=mtr should fit
05-02-2013, 09:36 PM | #4 |
I'm using these with 73 stands coated inside out should have no problems with your stands fit tight
Posted via Mobile Device |
05-02-2013, 09:40 PM | #5 |
What's the number on those?
05-02-2013, 10:17 PM | #6 |
310 delivered to Cali from josh at ky turbo their right up the road from Holley hooker cheaper than summit and got an actual deliver date where summit couldn't give me one. Really love the way the fit no stupid turns on the exit end.
05-02-2013, 10:18 PM | #7 |
Do you know the part number?
05-03-2013, 09:41 AM | #8 |
No just told josh what I was looking for you could just look at summit racing web site and get an idea. Plus i think factory part # would be different to anyone else. Just a word of advice mine are black ceramic and ended up turning a slight gray if your interested in that color. I'll try To find the paper work.
05-03-2013, 09:57 AM | #9 | |
05-03-2013, 03:39 PM | #10 |
I think Holley actually rates these at around 550 horsepower. I've never seen documentation as far as testing by independent shops. My opinion which really doesn't matter to anyone are seem to be quality made super smooth finish inside with no excess casting flash also outside coated inside out runners flow smoothly into the main. Everything just appears to flow so nice. They dump out the bottom nicely with no funny angles. Would not hesitate to buy another set.
05-03-2013, 03:49 PM | #11 |
i have a lot of customers that are using. 98-02 f body manifolds, they work well.
05-03-2013, 10:15 PM | #12 |
GM f-bodies are the way to go. The hooker ones are too expensive, where you can get the f-body ones for about $100 cheaper online through GM. From what i could tell, they're close to the same contour too, with a little difference in the angle of the flanges.
05-05-2013, 09:53 AM | #13 | |
05-03-2013, 10:18 PM | #14 |
On the first page of my build, i put up a bunch of pics of how the F-bodies fit compared to the stockers. http://67-72chevytrucks.com/vboard/s...d.php?t=504827
05-03-2013, 11:30 PM | #15 |
I agree with the camaros. Don't really care for the sheet metal look so I would have remove them then would have to grind the mounting points then the ceramic coating was another $100 plus the gas to the ceramic shop was 45 minutes away trust me I went back and forth between mine Doug thorley $415.00 headers and camaros this was most logical for look and performance.
05-05-2013, 02:10 PM | #16 |
Registered Cruiser
I'm using TBSS Manifolds, the hug the block nicely and are about $60-$70 a piece.
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
05-05-2013, 05:51 PM | #17 |
I have a set of 99 Camaro manifolds with O2 sensors I'm going to list in the 4 sale section. I bought them and had to buy headers when I put my 5.3 in my S10. I was wondering what they might be worth.
