Guys i need some help. While going from my th350 to sm465 my strap broke and so my sm465 fall to the ground about 2 foot... Since then i've been trying to get the top cover off to check it out and can't. In reality i don't know what would be bad or good so i need some help. Any idea's?
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: SM465 Cover Help
I wouldn't worry about dropping an SM465 from 2 feet. I'd guess you could drop one from 20 feet and the damage would be to the concrete more than the trans.
If it didn't crack something obvious or damage anything external you shouldn't have to worry much. The internals are guaranteed not damaged. Posted via Mobile Device |
#3 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
But part of what made me second guess that is it's in 2nd or 3rd and i can't get it to take other gears. It won't even try.
Did it land on the shifter ?
On the input shaft/bottom of case seemed more on shaft though. The shifter was out.
Sounds like reverse slid on you when you put the cover back in place.I put some grease on the shaft to hold the gear in place while installing the cover.
The case is fine, so's the input shaft. But now it won't free shift... Which is what started the 2nd guessing. I don't wana put it in only to have to drop it once i put the cab n dog house on. It did make a nice indention in my dirt lean-to lol.
#9 | |
To get the cover off take all the bolts out of the cover to trans. Engauge 1/2 way into reverse and it should come right off.
I can't get the cover off cuz the shifter is "stuck" it feels like in neutral. It won't take gear. Not low or reverse.
I think i got it. I lined the 3 bar slots in the top cover and it come right off. Put the gasket on and all is good so far...
Tags |
inside, sm465, transmission |
