column shifter handle???
Is there a trick on puting on a auto column shifter handle?
I cant seem to get it in? |
![]() Join Date: Sep 2001
No trick from what I remember. There's just a pin that holds it in place on the outside, and that pin operates as a pivot point. The end of the handle I'm not remembering for some reason.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
I'm having the same kind of problem. I bought a new aftermarket shift handle and it seems to not fit where the old one goes in. But after inspecting it, I notice that the roundness at the end of the newer handle is a little wider than that of the older handle. And the slot that it fits into is round also, but I guess the new shifter is a little too wide. So the best thing to do is probably grind off a little at the end. Haven't gotten to it yet, but seems to be the problem...
![]() JAA
1971 Chevy Longbed Fleetside Chevrolet All The Way! |
