3 + 3 Dually inot 3 + 3 SRW?
I'm looking for a C20 or C30 3 + 3 square body (73-86) with single rear wheels. Seems like most of what is out there are duallys. Is it possible to remove the outer wheels and do something to the bed (replace it???) to convert a dually to single rear wheels?
Re: 3 + 3 Dually inot 3 + 3 SRW?
yes it is possible I did a 2wd dually into a 4x4 single. have to get a bed change the front rotors. get a single wheel 14 bolt since the dually axle is a different width. may have to move the spring perches depending on what axle you get
1985 ![]() |
ive actually seen people used a srw bed and use the drw dana 70 with single wheels. the wheels actually set about a .5 inch out from the fender rather than set a inch or two in with the 14 bolt and looked better. you can also if you want change the bedsides out a the drw bed if you need new metal as its hard to find a clean srw bed sometimes. you do need to change the front rotors like said above other wise your front will are going to be setting at a funny track width.
the truck that used the 70 was in the project threads.
no, its impossible, find a srw truck
"DON'T TOUCH THE TRIM!!"-Early Kyler |
dude i was joking, all you have to change is the bed and rear end
oh ok i wish i could find a srw swap with d70 it acutally looked real good.
#10 | |
What are we supposed to be looking at? And OP, why don't you want a dually?
Few things in life will make you look stupider than putting a dollar sign after a number. |
I don't need the dual rear wheels for anything I will be doing with it (as far as I know
![]() ![]() Sounds like this may take a skill set I do not have and may cost more than it is worth. Probably better off finding a srw to begin with (although they seem to be few and far between compared to drws, at least around here.) |
#12 | |
srw conversion keeping the d70 rather than the 14 bolt. i like srw truck better looks and to drive also. kinda like asking y do you like mustard on your hot dog and not relish.
SRW bed + aftermarket wheels with a backspacing that keeps the rear wheel tucked behind the fender line. No idea what backspace though. Tape measure will be your friend once you get a SRW bed in place.
Alex. |
#15 |
Looking for this?? there is a build thread somewhere
67- 72 Parts collecter |
#16 |
would love that truck if it was a longbed.
#17 |
Longbed????? They are getting rare!!!!
#18 |
I kinda feel your pain any 1 ton truck here is a dually and rusty or its low miles super clean and worth a ton of money.
