Hey all ,
I have a stock '72 Chevy C10. I am trying to replace the exterior gasket on the fuel filler neck -- without taking out the filler neck itself. I looked in the service manual for instructions, for 'how to' videos on YouTube, and threads here in the forum, and haven't found anything that helps. Any one know the best way to do this, or can point me to a website or video that shows how to do it? Let me know -- thanks! Township21 |
Re: Tips for filler neck gasket replacement?
I need to do the same thing just have not gotten around to it yet. Thanks for asking I will be checking back.
Old member
I don't know about it being the best are not but I can tell U how I did it and it was pretty easy.
Take the gas tank bolts loose so U have some play up at the neck and coat the neck with dish washing liquid to help it go in place. Warm the gasket up also in some warm water before U start. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I cant find the thread right now, but I remember reading how alot of people use dish soap on the gasket it to help slide it in place.
I ordered one from Wes (read alot of bad reviews about the more common gaskets cracking after 6 months or so), but waiting to do my body work and paint before installing it.
71 swb 350/4sp manual 5/7 static drop |
I used the dish soap and warm water trick without loosening the tank. Just pushed it in place.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Thanks all -- I'll give this a try!
One quick q for KSShane -- I'm intrigued by your comment about 'common gaskets'. I just ordered one on line -- who is this "Wes" that you referred to? |
Soap on the gasket wasn't enough for me. It was way too tight on one side. I took a thick shovel handle, put it about 8" down the open fuel neck, then leaned on the handle gently to create a gap while I got it in place.
Have a wide flat head screw driver handy to push the edges down in to place |
Tags |
filler neck, gasket, replacement |
