09-12-2014, 10:19 PM | #1 |
What pump to use in a 87 factory tank?
I am helping a buddy with his build on a 1982 chevy that he will be putting a 2003 5.3 and 4l60e. He wants to use a 87 factory tank and sending unit but replace the pump with a high pressure in tank pump. What pump would be the best to use?
Thanks for the help!
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
09-12-2014, 10:50 PM | #2 |
Re: What pump to use in a 87 factory tank?
Hello. If i remember correctly, 1987 c10 square bodies have a TBI fuel injection. If that's the case the ac delco ep381 pump should be easily swapped for the TBI fuel pump. Good luck.
09-12-2014, 11:39 PM | #3 |
Thanks for your help dec
09-13-2014, 09:57 AM | #4 |
Old member
If the tank already has a intank pump just buy a replacement pump for the motor the truck came out of and install it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-02-2014, 12:35 AM | #5 | |
BMW & ASE Master Certified
the pump mentioned above.. Think the application was a tuned port corvette
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
10-02-2014, 08:12 AM | #6 |
ac delco ep381 IS WHAT I USED IN MY 80 SUBURBAN TANK
10-04-2014, 09:27 AM | #7 |
I just went to the parts store and ordered a in tank pump for a 2003 Camaro with a V-8
Works great. maybe it was the same as the EP381, did not save the box! It fit the 87 small tank 16ga. and the sender was for the 87 also and now I have a working gas gauge!
10-04-2014, 04:12 PM | #8 |
Thanks for the help guys. We just put a walbro 255 on the 87 sending unit. I just had to solder the wires because it had a different plug. Other than that it fit great. We also put a new 87 tank in his truck to have the baffles. Total I think he spent around $240 for new tank, sending unit and pump.
