LSx fuel supply without AN fittings.
Looking to see options for building a LS fuel supply system without an extensive use of AN fittings.
Basically all factory vehicle fuel systems run a short section of flexible line near the tank and a short section near the motor. That is what I want. What kind of options do I have? Suggestions? Pics/part numbers? |
Re: LSx fuel supply without AN fittings.
I used an in-tank pump, on the pick-up for an '87 TBI truck. It just uses push on hoses for supply and return. You do want the proper hose clamps for efi. The best hose I found is Gates Barricade EFI hose. It comes in two pressure ratings. You want the higher. I have hard line down the frame rail, with a fuel filter halfway, turning up just behind the starter. You can use the same hose from here, to the fuel rail. You will need a barbed fitting that fits the fuel rail. Most parts stores have them.
Be sure to use a heat sleeve as the hose crosses anywhere near the exhaust. I also used a tool called Clamp-Tite to apply stainless safety wire hose clamps, rather than worm drive, or worse. You can apply heavy heat shrink, such as that used on AC wires that feed your house, over the wire clamps to make them look more factory. Google the tool.
Scotty Baccus |
meowMEOWmeowMEOW
I always add this; if you plan on taking the truck on any NHRA drag strips, having more than a foot of rubber hose (even the EFI approved stuff), will fail tech.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
The Waco Kid
You can check out what I did here: http://67-72chevytrucks.com/vboard/s...=585899&page=5
Posts 107-118, 145, & 154 |
#5 | |
The Dorman nylon fuel line worked well. I also added the summit heat sleeve to the section that transitioned from the frame over the planned exhaust routing up along the back side of the transmission for added protection.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
http://www.corvetteforum.com/forums/...uel-rails.html
This is a link to how I converted my SS factory hard lineson my C6Z to accept AN line to the fuel rails. If the "russel" part would have failed while I was road racing, it would have been all over. Here is a link to the MFG part # http://www.swagelok.com/search/produ...t=SS-600-6-6AN |
meowMEOWmeowMEOW
The Russel part with aknowledged failure is the early part # PTC fittings, not any of the compression fit or flare fit parts. The failure was due to poorly designed inner retaining clips, and not any inherent failure of a brand. It has since been replaced with a capped clip that can't really fail.
I think I mentioned in my build thread..
What i used was Dorman nylon fuel line and fittings. It's found in a lot of OEM applications, it's cheap, it's easy to work with. If you wanted you could adapt it to a run of steel line along the frame and use the nylon to get to the rail. Any 3/8 barbed fitting will work - no need to buy special tools, either - just take your time and it all goes together pretty easy. If I were building a race car or street / strip machine I'd go AN. Since I'm not... the nylon line was perfect.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
#10 | |
Exactly what I was looking for. And I agree with you, race/strip car would definitely be getting AN fittings. |
Very easy to do with the blazer tank and modified stock sender/pickup assy and an intank pump . Using stainless hard line, with compression fittings and push lock hose !
I will have a complete new intank pump assy for sale very soon. Upgrading to twin turbos ! |
