01-03-2015, 03:24 PM | #1 |
"Strapped For Cash"
Started this build with $300.00, Bought a rolling chassis and went to work. The problem was, that I wanted a short bed and all I could find was long beds. So, I made my own.
01-03-2015, 03:26 PM | #2 |
Re: "Strapped For Cash"
Welded and plate behind the cut and boxed it in to reinforce it.
01-03-2015, 03:28 PM | #3 |
Had to find a donor for mock up. I used this truck to made sure everything was going to fit before I powder coated everything. The problem with this truck was, it was also a long bed.
01-03-2015, 03:30 PM | #4 |
So I made my own.. I figured I could use this bed on my other truck that has a step side now.
01-03-2015, 03:32 PM | #5 |
Next I had to pick and engine to work with. I came across a 5.3 with a 4L60E. Cleaned it up and mounted it.
01-03-2015, 03:35 PM | #6 |
The rear end came out of a 2002 Camaro. Im also going with an air ride suspension.
01-04-2015, 07:44 PM | #7 |
When you cut your frame to shorten it, how did you make the rounded cuts with the cut-off wheel?
01-04-2015, 08:37 PM | #8 |
I used the sawzall and then shaped the round edges with an angle grinder.
01-04-2015, 08:47 PM | #9 |
Use the sawzall to get your way in there, enough to be able to get at it with the grinding wheel afterwards. Cut and fit, till it fits perfect. The first one I did took about 4 hours. The last one I did took about an hour.
01-04-2015, 09:37 PM | #10 |
BigBlockBobby
Nice work .. it's going to be sweet
Bob |
01-04-2015, 10:24 PM | #11 |
Hey if you dont mind saying what did they charge to sand blast and powdercoat your frame?Im looking to get mine done and was wondering what is a good price.Thanks oz
01-10-2015, 11:47 PM | #12 |
$350 to sandblast and powder coat.
01-11-2015, 09:39 PM | #13 |
Wow!!
Last month I just spent $350 for just sandblasting on a clean frame and it took over 3 weeks for them to finish it
______________________ www.northeastrodrun.com |
01-12-2015, 01:00 AM | #14 |
Yes I flipped the carrier bracket. My shaft angle was way off.
There a guy here, near Temecula that I've been using that is good and cheap. |
01-11-2015, 01:57 AM | #15 |
What wheels are in the pic? Coy C5s? Which wheels are you planning on running?
01-11-2015, 11:16 AM | #16 |
Those are Torq Thrust. I haven't decided what to run yet
01-11-2015, 11:42 AM | #17 |
Sorry I forgot to tell you great work so far. I'm in for this build.
01-11-2015, 07:47 PM | #18 |
Look'n Good in the Neighbor hood!!!
Did you just reverse the carrier bearing bracket?, or is that a new bracket you purchased??? |
08-02-2015, 11:22 PM | #19 |
I'll post some updates on this tomorrow...
11-18-2015, 01:33 AM | #20 |
I haven't had a chance to get any pictures up. I have the complete truck on instagram. Check it out, it's under user art_molina
I'll post pictures... |
11-18-2015, 01:46 AM | #21 |
Here are some pictures, Had the entire truck sandblasted and powder coated with black primer..
11-18-2015, 01:50 AM | #22 |
Some more pictures.. The last pictures shows my 69, parked out front.. waiting it's turn.
I managed to fit 20x10 all the way around, had to mess with the tire size to get them not to rub.. Looks pretty good, I think.... |
11-18-2015, 01:52 AM | #23 |
Heres the frame, before the body... I got rid of those stock upper control arms, I went with tubulars so I could run the 20x10 up front without rubbing issues.
11-18-2015, 04:33 AM | #24 |
Can't believe you had the hole truck powder coated it looks slick love the build
11-18-2015, 08:47 AM | #25 |
Very awesome build. Truck looks sick
