'Burban Build
I have been a member here for a little while, but mainly just lurked around looking at all the cool trucks. I bought this 90 Suburban last year and had big plans for it. Like many projects the excitement fizzled out a little and I put the truck up for sale. After getting a lot of low ballers and looking at justpball's build thread 100 times I have decided to continue on. My plan is to have a cool static dropped family hauler to attend the local cruise in's and car shows. I also am hoping to be able to keep it tow worthy if possible. Anyway here is the truck the day I brought her home...
![]() ![]() Like I said it is a 90 model with the stock TBI 350 and all the power options. It was running rough when I bought it but I felt like the motor was good. It ended up needing an EGR valve and the throttle body cleaned and now it runs perfect. The radiator also looked suspect so it got a new one along with hoses, thermostat, and a new belt. I drove it for a few weeks like that and then had to get it closer to the ground. After installing 3" spindles & 2" springs up front and a flip kit with 1.5" lift shackles in the rear it now sits like this... ![]() I also installed new ball joints, rotors, pads, calipers, brake hoses, and shocks at the same time. I had a little drive line vibration so I installed 4 degree shims and spaced the carrier bearing up a little. It now rides great, but on big dips will just touch in the rear so I have a c-notch on it's way. I also have new carpet coming and the headliner will be getting replaced soon. I wasn't planning on documenting this so the pictures are lacking up to this point, but will definitely take some from here on out. Stay tuned... Last edited by Mr_Shamrock; 02-02-2015 at 11:06 AM. |
Re: 'Burban Build
Another pic (just because) with a couple of my other trucks...
Re: 'Burban Build
I'm following. Cool burb.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
Re: 'Burban Build
hey there, awesome looking burb. looking to lower my 77. you did a 3"spindle 2" spring. then a flip kit for the rear. you didn't have to c-notch the frame?
Re: 'Burban Build
I have a notch coming. It only slightly touches on large dips, but that has been with just me in the truck so once it gets loaded down it will be worse. They don't make a notch specifically for these truck. I found a deal on one for a 88-98 truck since they are straight framed above the axle like our Suburbans. I should get it in the next few days and hope to get it installed this weekend or next. I will post my results.
LifeTime GM guy. Current collection...
2006 Z-71 Suburban 1985 C-10 1990 Suburban 1966 C-10 (me & dad's project) |
Re: 'Burban Build
Following... Nice burb. It definitely sits up higher than mine with the same drop. Mine suffers from saggy but syndrome though.
![]() How much did you end up shimming your carrier bearing?
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver. 86 Short box just starting the build. 86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come! 98 Cheyenne Ext cab short box 2wd. Driver and maybe future project. |
#7 | |
Re: 'Burban Build
Did you use lift shackles or just do the flip? I used lifts shackles.
Re: 'Burban Build
Great lookin Burb!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
Re: 'Burban Build
Love it! Great job!
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
