05-26-2015, 10:43 PM | #1 |
TH400 howl
Anyone ever have a TH400 with a howl between, say, 20-30 mph? Only when torque is applied, not coasting. This is with a 4.57 rear, btw. Any thoughts? Bearing?
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
05-26-2015, 10:46 PM | #2 |
Re: TH400 howl
Are you sure it's the trans? I've had rearend a make some god awful noises but never an automatic trans.
At my worst I'm at my best |
05-26-2015, 10:52 PM | #3 |
Re: TH400 howl
It seems to be the trans. The rear end seems quiet. Replaced carrier bearing in the drive shaft as well.
05-26-2015, 11:12 PM | #4 |
Re: TH400 howl
Check the converter
05-27-2015, 10:53 PM | #5 |
Re: TH400 howl
The torque converter? Check for what, specifically?
05-27-2015, 11:10 PM | #6 |
Re: TH400 howl
When they go bad they growl/howl. You should hear it with the rear on jack stands. Have someone help you! Don't climb under with the truck in gear.
06-25-2015, 11:35 PM | #7 |
Re: TH400 howl
I would think if its the TC, the noise most likely would be heard all the time....the noise is being heard at a specified road speed range. Correct ? Maybe a torrington bearing in the T400 is coming apart....just a thought. (planetary area) Drop the pan on the trans, maybe piece of the bearing in the pan along with a bit of metal... Good Luck.
