Picked up an NV4500
I snagged an NV4500 today for $75. Got it home and start to look at it and it seems to be somewhat unique in the NV4500 world.
It decodes to a '95 from a C-truck with the late 5.61:1 1st, and the early normal GM bolt pattern. So 1st/low isn't quite as granny as the 4-speeds and it'll bolt to an early bellhousing, which makes a swap cheaper. It also came with the bellhousing, slave, TO bearing, inspection cover, 12" pressure plate, big flywheel, and shift lever. Now the bad news. I looked at a flywheel from a truck I parted a while back that had a 350, and its an unbalanced flywheel, which suggests I let a stroked 350 (383) get away for cheap. Oh well. |
Re: Picked up an NV4500
I guess what I remembered about the trans to BH bolt pattern was not right. Oh well.
Tags |
nv4500 |
