Old 07-08-2015, 01:58 PM   #1
Rust-O-Matic
Rust-O-Matic's Avatar
another '66 front shock relocation bracket question
What's up fellas? I am about to fashion some simple brackets to raise the upper shock mounting point on the front of my lowered '66 C20, and just had a thought I wanted to run by you guys. I drilled out the original rear brackets and made some out of tubing per Lakeroadster's thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=451200
It looks to me like I could trim the original rear brackets and weld or bolt them to the frame above the original front mount stud locations. Has anybody else done this? Mounted to the side or top of the frame rail? Any pics? I realize I'm surely over thinking this, as this is a very simple task, but I am curious to see how others mounted theirs if this has been done before.
Rust-O-Matic is offline   Reply With Quote
Old 02-08-2016, 03:33 PM   #2
Rust-O-Matic
Re: Another '66 front shock relocation bracket question
I finally got around to trimming these old rear shock mounts up this weekend. These will be welded to my frame rails, moving the upper shock mount about 3" upward. Very similar to the aftermarket relocators available, except free.
In case anybody cares, here's some pics.
Old 02-08-2016, 03:50 PM   #3
Chevymann66
Chevymann66's Avatar
Re: another '66 front shock relocation bracket question
Awesome job man. I was just trying to figure out how I was going to relocate my aswell. Thanks for posting
---1964 C-10 SBW -Short Bed-
---1966 C-10--350 V8-4 Spd-BBW-Short Bed- SOLD!
---1964 C-10 :283 V8 -BBW Long Bed
Chevymann66 is offline   Reply With Quote
Old 02-08-2016, 04:46 PM   #4
Rust-O-Matic
Thanks! I'm kinda surprised I haven't seen them done like this in other posts. Maybe no one bothers with it because the aftermarket ones are readily available. No thanks, I'm a cheapskate.
You'll need an extra pair of shock bolt sleeves too, if you wanna use a standard 1/2" bolt on the top of each shock. The stock upper eyelet of the shock doesn't have one in it. The size you need are 1/2" i.d., 5/8" o.d., and approx 1 3/8" from end to end. I got some off of ebay. Not sure if local parts places carry them or not.
Old 02-09-2016, 01:46 AM   #5
Captainfab
60-66 Nut
Good thinking making use of old parts. Post up some pics when you get them installed.
Old 02-09-2016, 03:05 AM   #6
WOLFMANmike
WOLFMANmike's Avatar
this is what me and my friend did to mine
i went from this
WOLFMANmike is offline   Reply With Quote
brackets, relocation, shocks
