07-15-2015, 08:54 PM | #1 |
List of must do's
Ok, I am asking for help for some of the "must do's on my list as I am running out of time to do the research find the answers or relying on my memory, which is not working well now that I haven't worked on a vehicle of this era in a few years.
I have tried to add what problems I have run into performing the tasks and their solutions I have used. If I had more tools and equipment as others probably have access to would have made some answers easier. But all solutions I feel give everyone more power to help themselves and other if shared. I hope this info helps others. I really would appreciate any input and if others have question on their project that relate to common task such as these, feel free to ask or comment. 1: ) Fix passenger side door handle-push button getting stuck need any info on why the spring/plate doesnt seem to have the guide to keep it in place while opening the door. 2: ) replace wood bed- while trying to get the wood panels off the bed found most are breaking-where the heck do you get an 8-point socket - even Sears(craftsman) doesnt sell them anymore 3: )fix leaky wheel cylinder on rear- issue wheel cylinder leaking due to out of spec drum, - solution drum replaced issue but 1/4" too deep in braking material area.cant find replacement- solution -trying to retrofit a 14 bolt- axle- in place orig brake line and wheel cylinder issue shocks too short solution replace with replacement of 73-up shock issue staggered shock mounts on axle solution move orig shock mount use (find size) bolt/nuts and move to rear of passenger side axle 4 : ) issue replace leaky heater core solution bought heater core issue still no heat solution dont need heat until winter -do later haha 5 : ) issue carburetor leaking solution rebuild carb _DONE YAHOO 6 : ) turn signal doesn't turn off(on left turns) or signal(left turn) in cab Last edited by racerop; 07-15-2015 at 08:58 PM. Reason: edit didint realize : + ) = :) and missing shift and ; + ) = ;) |
07-15-2015, 09:10 PM | #2 |
Re: List of must do's
I really like these mirrors on this truck, the tri-pod kind bounce too much going down the road. Are these any better?
07-16-2015, 09:53 AM | #3 |
1. Get another handle off the parts section
2. Twist or grind off all hardware and get new. 4..flush radiator and replace thermostat 6. Check the canceling cam in colum I have those mirrors and they dont bounce. They are a little noisey wind wise
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
07-16-2015, 10:24 AM | #4 |
I'd go with a rear disc brake set up and Vintage Air. That's what I'm in the process of doing to my 68
07-16-2015, 06:47 PM | #5 | |
I have looked at replacing the air conditioning unit with one that fits under the dash, the two I have looked at are contenders |
07-16-2015, 05:34 PM | #6 |
need any info on why the spring/plate doesnt seem to have the guide to keep it in place while opening the door. Do you mean it cant be fixed? the chrome seems to be in great shape, the button some times gets stuck(sideways) and the spring that pushes it back that gives you the tension seems weak. 4 : ) issue replace leaky heater core solution bought heater core issue still no heat solution dont need heat until winter -do later haha I did a flush and have changed the fluid....plus capped off the heater core so water doesn't go through.....I should have stated that, I have to get the time to change out the heater core Cool I wanted to replace them with a set of them. |
07-16-2015, 05:50 PM | #7 |
Door handle problem can't really be fixed as they are pot metal. People sometimes surprise me with creative solutions but I've never heard of anybody fixing these. Mine were pitted anyway so I was fine with getting a replacement. Gmc Paul's and Brothers sell better made than original handles that won't break like the originals did so often.(so they say anyway, who knows) they're 50-60 bucks for a set. I'm sure they are also some for sale on the parts board like the other guy said. I got mine from brothers and they seem really nice. Outside looks stock but the inside is slightly different due to "upgrade".
07-16-2015, 06:04 PM | #8 |
Hello from a fellow Mobile Al member @Custom/Ten
US Army Bomb Squad 83-96 There is no problem that a suitable amount of explosives cannot solve |
07-16-2015, 06:51 PM | #9 | |
07-16-2015, 06:53 PM | #10 |
Haha, good idea!
07-17-2015, 04:13 AM | #11 |
Oh gosh, too much to list so I'll sum it up:
Finish the "soft rebuild". Get licensed. Drive remaining nice days before winter. |
07-17-2015, 06:05 AM | #12 |
